petit_bateau
3 knots sounds achievable for short distances with suitable tyres (terrible fuel consumption though both in water and on land).Can 3 knots be possible just by spinning tyres?
Hubs sounds like a complete red herring.
Hub caps that hinge/ petal open into paddles might be possible.3 knots sounds achievable for short distances with suitable tyres (terrible fuel consumption though both in water and on land).
It sort of has to anyway. States use salt on their roads, people live on the coast, engine bays on ICE are already built to be (reasonable level of) pressure washer proof. The key additional items needed are vent line heights and cabin sealing (esp door drains).I have a lot of trouble with Elon's claim that CT can be used as a boat for short periods. Does he really think that he can seal these things up to withstand a saltwater bath? Why would you go to the trouble to do that for an affordable pickup truck? (Not that it doesn't sound really cool.)
Should even be better than that, Megacharger is four V3 cabinets hooked to one plug.Haha, yeah, 650KWh/500mi = 1.3 KWh/mi. I wonder if there's less 'pepsi' and more 'frito lay' in those wagons... That's gotta be at 60 mph. Or maybe routes from the Modesto hub are more urban (less interstate?).
No matter! Build the damn thing, and ship it already. The time has come!
Cheers!
P.S. This 650 KWh pack size also reveals that MegaCharger is capable of at least 900 KW sustained charging rate. 650*0.7*2
Tesla Megacharger installation at Giga Nevada wraps up construction
Sure, but that calc is a pack limitYeah, that's a sensible spec for long-term reliable charging. V3 currently provides 250KW, times 4 would be a megawatt peak. But the 900KW is the sustained charge rate over the first 70% of the packs's SOC. So 1MW peak at low SOC is fine, and hopefully not tapering too quickly.
Cheers!
Each V3 cabinet can provide ~360kW. So with 4 cabinets they should be able to charge at up to ~1.4MW.Yeah, that's a sensible spec for long-term reliable charging. V3 currently provides 250KW, times 4 would be a megawatt peak. But the 900KW is the sustained charge rate over the first 70% of the packs's SOC. So 1MW peak at low SOC is fine, and hopefully not tapering too quickly.
Cheers!
I used to fly Grumman Mallards in the VI. We could never keep the salt water out of anything. Electronics were the worst but the whole plane was subject to corrosion.It sort of has to anyway. States use salt on their roads, people live on the coast, engine bays on ICE are already built to be (reasonable level of) pressure washer proof. The key additional items needed are vent line heights and cabin sealing (esp door drains).
Basically, it's an extension of good life extending engineering design.
It will be super exciting to watch that charge cycle ramp up.Each V3 cabinet can provide ~360kW. So with 4 cabinets they should be able to charge at up to ~1.4MW.
Not so much being sticky, the link bar is heavy and the magnetic field (also fighting the return spring) gets stronger the closer the switch is to being closed. So the bar is accelerating all the way until contact. Tesla treats theirs kindly (precharge), but they are rated for high voltage/ current so it wants to move fast when opening/ closing.It will be super exciting to watch that charge cycle ramp up.
Back in the day, when Model S was made prior to superchargers or any compatible DC fast charger so the first time a Model S was plugged into a Supercharger the contactors would need to retract to initiate charging. Well, for some of us that was quite a harrowing experience. The sound of those contactors moving was so loud (as I assume were a bit sticky) that it caused me to jump out of my seat. It sounded like a loud and deep 'pop', but thankfully, as I stood outside the car (possibly a safe distance away) it started the ramp up. The following year, as I was working on AP camera calibration at the end of the line production line and heard the same sound, but very faint and noticed that right after calibration they were plugging in cars before going to the test track. This was the first time these had been supercharged and were making the same sound but obviously it was much less. By 2015, I couldn't hear that sound anymore. Yet another reason why Tesla is leading electric vehicles.
Should be better than that if you are talking pure altitude effects. Downhill has near 100% energy conversion efficency (if slope less than that needed for maintaing speed). Uphill is motor efficiency shift * driving load and operating efficency * potential energy gained.Don’t forget regen. Tesla Semi get back 70% of the energy spent up hills on the way back down.. ICE semis do not regenerate fuel.
Unless you have a lot of trucks and accelerate the air to truck speed.No, won't the tunnel limit how air flows past the truck? Almost like a Venturi effect; or all the air the truck displaces now has only that little room between the truck and the tunnel sides to squeeze through so it has to go through faster making more wind resistance, not less.
My understanding is that yes, for one freight container moving through a tunnel, the air drag is much worse than running it at the same speed on the highway, but if you have a series of freight containers in a train (whether directly linked together with mechanical connections or more likely software-linked) then the containers behind the lead container can ride through the slipstream with much less drag, such that the overall average drag per ton of freight for the platoon is less than if the same containers were shipped at the same speed on with a platoon of semi trucks on an aboveground highway.No, won't the tunnel limit how air flows past the truck? Almost like a Venturi effect; or all the air the truck displaces now has only that little room between the truck and the tunnel sides to squeeze through so it has to go through faster making more wind resistance, not less.
It would be a very unique slope to be able to coast all the way down. In the real world, you are going to need to use regen, and thus recapture less than 100% of the uphill energy.Should be better than that if you are talking pure altitude effects. Downhill has near 100% energy conversion efficency (if slope less than that needed for maintaing speed). Uphill is motor efficiency shift * driving load and operating efficency * potential energy gained.
