That wording still has the lane vs lanes issue and except.Here's a quick visual if this helps. I've seen signs constructed like this in and around DC.
I think ChatGPT understood my description, lane numbering and all, but logically grouped these phrases as "No turn on red (except from right lane Mon-Fri 7-9 am 4-7 pm)" instead of logically grouping them as "(No turn on red except from right lane) [applies only to the periods] (Mon-Fri 7-9 am 4-7 pm)." The default state is that right-on-red is allowed, so outside of the specified time periods, it's allowed from both lanes.
Even clarifying that it's constructed this way doesn't change the answer:
Check out that front suspension.I love and hate this so much. Such a tease.
Obviously they did a crash test on the Cybertruck, but won't show the outcome.
That connects it to the pull mechanism (center track) for the test.
Why not both?True, so lets look at any chemistry and the reasons that discharge rates are higher than charge rates. Certainly it's beneficial to keep internal heating within an acceptable range but the limitation in charge rates seems to be more tied to the diffusion rates of the anode than internal resistance of the tab structure.
@EVNowSeems pretty obvious to me that Tesla need to anonymise the videos, same way that Google Maps does - licence plates and faces are blurred. This isn't difficult to do and less of a risk compared to Google whose images are in the public space.
So I see an easy response from Tesla and they should implement and announce sooner rather than later. Don't understand why they haven't already.
Cybertruck wiper in action.
Prepping for wind tunnel?
Yah, a big wiper arm with two standard blades mounted to it.Geez Louise! That's one big a** wiper!
S/X refresh was total overhaul. Vehicle electrical architecture redo is simpler and involves the 86% Tesla modules going to 100%. This can be done and validated on current vehicles before lone switchover. Depending on architecture, it can also be done in stages with gateway/ translator end nodes to legacy modules.The most likely way to achieve that on existing models would be to retire their production and replace them with a product designed from the ground up with those improvements. This, rather than make those changes to an existing production line and disrupt the production rate. Remember the revamp of S and X?
I'd like to see new models and factory come on line with fresh replacements for the high end vehicles, then retire the existing ones. This isn't likely to happen as the focus is now on higher production of lower cost models, as well as new models for other market segments Tesla hasn't addressed (Vans, Pickups, Semis, Robotaxis).
Gigawiper.Geez Louise! That's one big a** wiper!
