Figured it couldn't be semiTo be clear I was talking about a single motor Model 3 type vehicle.
300 Wh/mile @60 MPH = 1.8kW = 24 hp
250 Wh/mile = 20 hp
More accurately installs the plugWas thinking about drive by wire and every time they are brought up it seems like redundancy requirements are big. I think this is why the traditional steering assembly has lasted so long. But very possible Tesla pulls the plug with Cybertruck or Gen 3.
You can’t do this with brakes or front steering though.More accurately installs the plugI'm assuming the rear steering for Cybertruck is drive by wire with a default return to straight mechanism.
Return to center, if powered. Assuming it uses this:More accurately installs the plugI'm assuming the rear steering for Cybertruck is drive by wire with a default return to straight mechanism.
I'd think you'd want a mechanism which would return to center on loss of power.Return to center, if powered.
Maybe... depends why it was turned when power was lost.I'd think you'd want a mechanism which would return to center on loss of power.
My thinking is there are very rare occasions where you need rear steering, obviously most vehicles don't have it, so getting somewhere is more likely to happen if the rear steering fails to the straight ahead position.Maybe... depends why it was turned when power was lost.
All brake systems are dual loop, one hole still gives braking on two wheels.The wire harness patent seemed to indicate a bidirectional power flow loop, with each node potentially being able to receive data and power from 2 separate directions, Hence a single break in the harness would not necessarily knock a node offline, From the node to the device being controlled is likely to be a single set if wires, but a short run.
I'm not really convinced electronically controlled brakes will be less reliable than hydraulically controlled brakes. A single hole in the pipes can cause off a the brake fluid to leak out, potentially losing all 4 brakes at once. For electronic control, the most likely failure mode is 1 out of 4.
Like everything else it can be tested and the safest path is make the rear brakes electronic first, keeping the front brakes hydraulic until reliability is confirmed in real world use.
Good point, but I still wonder if there is a scenario (with a single hole) where all of the fluid can leak out, or at least where the fluid level can drop, or air bubbles can be introduced. They have probably though of that, I imagine there would be some kind of valve to shut the leaking section off from the good section?All brake systems are dual loop, one hole still gives braking on two wheels.
Yep, master cylinders have two sections so you can't lose all the fluid in both.Good point, but I still wonder if there is a scenario (with a single hole) where all of the fluid can leak out, or at least where the fluid level can drop, or air bubbles can be introduced. They have probably though of that, I imagine there would be some kind of valve to shut the leaking section off from the good section?
I think electronic brakes might need 2 separate independent power feeds per caliper, each with it's own backup power source near the calipers, and redundant signal lines. That way if one power or signal line fails there is a backup, if both power feeds to a caliper fails there is still backup power, and if the main pack goes down there would still be enough power for at least one braking event on each wheel. Maybe overkill but the extra cabling seems like cheap insurance, and possibly a super capacitor could have enough power for a one time backup event.
Niron’s first offering will be followed in 2025 by a magnet with an energy product above 30 MGOe, according to Blackburn. For this he makes a rather bold prediction: “It’ll have as good or better flux than neodymium. It’ll have the coercivity of a ferrite, and it’ll have the temperature coefficients of samarium cobalt”—better than NdFeB. If the magnet really manages to combine all those attributes (a big if), it would be very well suited for use in the traction motors of electric vehicles.
Or Tesla is working/buying from Niron. They often speak in the present tense stuff that is 2 years away.
Tesla 2 years ahead?
Yes that seems much more likely. I didn't get the impression that Tesla had these motors ready for production anytime soon.Or Tesla is working/buying from Niron. They often speak in the present tense stuff that is 2 years away.
