Do you have a source? From Bjorn's video here, it shows that the rear motor is used to drive, and the front motor only engages when the car is in need of traction or extra power based on internal CAN data. The front is rarely if ever used.All the time.
My understanding is that regen is only on the rear.One other item of potential interest, the front motors are probably providing the majority of the regen. While not directly related to AWD and extra umph the front motor provides for acceleration, they would provide a lot more braking and regen than if just a RWD only car. And when it comes to tire wear, I guess it would depend on how hard you accelerated from a standstill and how hard you hit the regen for stops. If neither was hard, then I'd expect the rear tires to wear out faster than the fronts, which is one reason you need to rotate your tires if possible (not a staggered setup). However if hard acceleration/regen, tire wear could different?
Hmmm... Why would they do that? You get something like 65-70 percent of your stopping power from the front brakes, so why throw all that away and increase wear and tear on the rear tires? I do not have the OBDII connection and software to check the front motor info, just seems odd to throw away all that free energy if not using front motors for regen. I guess I will have to do some regen runs and see how it feels. If the car nose dives under regen then I assume that is coming from the front motors. I do not recall right now since I have been in Prius mode for so long trying to get FSD beta access and you get knocked if regen is too hard, but I've had enough of that style of driving...My understanding is that regen is only on the rear.
Electric AWD is AWD Cheat Mode basically. ICE cars with their systems need lots of slip before they can actuate and there's a big delay so there's no comparison with ICE.Good info on the AWD system from one of my fav YouTubers!
Front motor is only powered when either power requirements dictate or for traction control purposes.Do you have a source? From Bjorn's video here, it shows that the rear motor is used to drive, and the front motor only engages when the car is in need of traction or extra power based on internal CAN data. The front is rarely if ever used.
