Both of these things are addressed in the manual for the car:
Reverse
Push the drive stalk all the way up and release. Y
ou can only shift into Reverse when Model Y is stopped or moving less than 5 mph (8 km/h).
Neutral
Neutral allows Model Y to roll freely when you are not pressing the brake pedal:
- When in Park, shift into Neutral by briefly pushing the drive stalk either up or down to the first position.
- When in Drive, shift into Neutral by briefly pushing the drive stalk up to the first position. If Autosteer or Traffic-Aware Cruise Control (if equipped) is active, you must push the drive stalk up to the first position and hold it there for more than 1 second. In doing so, Autosteer or Traffic-Aware Cruise Control is disabled.
- When in Reverse, shift into Neutral by briefly pushing the drive stalk down to the first position.
Note
You must press the brake pedal to shift out of Neutral if driving slower than approximately 5 mph (8 km/h).
Park
Press the end of the drive stalk while Model Y is stopped.
![Arrow pointing to button at end of stalk Arrow pointing to button at end of stalk](https://www.tesla.com/ownersmanual/images/GUID-B80EE2FF-D0E5-4553-8289-33852DCF3868-online-en-US.png)
Model Y automatically shifts into Park to prevent roll-away while driving in low speeds. This happens whenever you connect a charge cable, unbuckle your seat belt, or open the door while in Drive or Neutral. Ensure the charge cable is removed, buckle your seat belt, and close the door before shifting out of Park.
Attempting to engage the parking brake above 5 mph (8 km/h) will result in emergency braking (see Emergency Braking).
To make it convenient to pick up passengers, you can also unlock all doors at any time by shifting into Park then pressing the Park button a second time.
