Tirerack has it cheaper and lighter than the TO version. I understand it doesn't have the foam, which might preferred by me.
The Porsche tire is 1 lb lighter, has .5" more tread depth, and .2" less tread width otherwise the listed specs are identical. However, that doesn't mean there aren't more differences that just aren't listed in the specs. Tread will almost certainly be different and sidewall stiffness could be slightly different as well. I run non T0 18" PS4S tires on my car and they work perfectly.Tirerack has it cheaper and lighter than the TO version. I understand it doesn't have the foam, which might preferred by me.
I came across this article on the BMW M3 PS4S recently and found it pretty interesting.
https://www.tire-reviews.com/Article/Should-I-Fit-OE-Tires.htm
The BMW OEM version sounds like a significantly different tire from the regular PS4S, more aggressive with more focus on feedback and responsiveness. I wish I could get the BMW version in Model 3 18" sizing!
Of course that doesn't tell us anything about the Porsche or Tesla PS4S, except to confirm that they may also be significantly different from regular PS4S, and from eachother.
The Porsche tires the OP linked to are XL tires as well. In fact, all PS4S 235/35R20's are XL.The Porsche spec tires will likely have extra strength for the rear tires of the car, as that is what supports the significant % of the weight, the engine being located in the rear.
Some Tesla tires are XL rated - for extra load or extra weight on all 4 corners.
That's great. So, the XLs might work. But I can assure you the tires are designed and made differently. It's better to get the tires that were designed for your car. Required - no; recommended - yes.The Porsche tires the OP linked to are XL tires as well. In fact, all PS4S 235/35R20's are XL.
I disagreed with this because it was full of wrong info, which is that the Porsche "might" not run XL tires in the front, and other guesses. That's not information, that's dis-information, so I dis-agreed.No need to get upset and thumbs down my previous post, I am just sharing information. Sorry to offend you with this information.
Every tire on the planet is a compromise. The tires designed for our cars are likely designed for efficiency, since they are EV's. Some people would like to trade performance for range. There is no universal "right" tire or one "designed" for your car. There is only a tire designed for the OEM's goals for the car they advertised to you, and it's OK to have different goals. This is why we have standards on what tires can be run, like load ratings, so you can determine what tire is appropriate for your car even if it isn't the OEM tire.But I can assure you the tires are designed and made differently. It's better to get the tires that were designed for your car.
Porsche actually makes more cars than a 911. The Porsches that use these tires are Boxters. Mid-engined, not rear engined. With 47:53 weight distributions, often described in the press as "near-perfect weight distribution". And they run much wider tires in the back. And the tires are all XL, with a 92Y rating, so they are perfectly safe to use on our cars, despite your guess that they "might" not be. In fact, they are exactly the same rating as the stock T0 tires, and fully meet the requirements on the door sticker.
By your definition, it would be a bad idea to put all season tires on a M3P because it didn't come with them, so you should just not drive it when it's cold out.
Because no 911 uses OEM 235/35R20 tires. Those are tires for a Boxster / Cayman. So 911 weight distribution is meaningless, and I'm not quite sure why you keep bringing it up. Notice the OP never said 911 at any point. Just Porsche OEM, and Porsche makes a LOT of different cars, including ones with engines in the front.Not sure why you are talking about Boxster tires
Cool. Here's the Model 3 manual on tires. Note it doesn't mention XL, load rating, brand, or T0 tires at all. Just a size, which the N0 tires absolutely meet:I said what is recommended from the OEM should be looked at.
What place lets you return used tires?I am returning the all season and getting the summer PS4S since I have those on my M5 and while they are not the most quiet tires I feel…… I except them to be more quiet on the S than the all season
You're in the Model 3 forum, with model 3 tire sizes. Your larger tire sizes may not overlap with an OEM tire from Porsche or BMW.Now all the intricacies with the BMW Verson VS the Porsche ….. I gotta check what I ordered.
Costco all the way baby on the returns ( they have a one month return policy on the Michelins )What place lets you return used tires?
I would not assume a 4S is quieter than a A/S 4 (no such thing as a A/S 4S). Larger tread blocks are generally noisier.
It seems you care about noise over performance, so picking an extreme performance summer tire is a very odd choice.
That's fine. I'm just saying that going for super performance tires is unlikely to meet that goal. Sounds like you want more of a grand touring all season tire, not an extreme performance summer. As someone with 4 sets of PS4S tires in my garage, I would not call them quiet.Let’s say I prefer a quiet ride in the Tesla to listen to music when I am being energy efficient on the roads.
You making me think really hard nowAnd here's Tire Rack's comparison of the 4S and the A/S 4:
If you're sensitive to the A/S being noisy, the 4S isn't going to be better. Consumers rate them identically.
But whatever, you mind is made up, so good luck. Report back when you get them and let us know if they really are quieter.
