People will find a negative way to spin anything. That's not the concern.
Taking care of the driver is the concern. Projected-in-the-instrument-cluster in old firmware did a far better job of that than Rated has.
Wrong. Your climate and roads may very. To get rated range reliably in my climate, elevation changes, and street conditions I'd probably have to sell my car since I would be a traffic hazard (going too slow, impeding traffic).
And, yes, I have tried. It usually involves going 5-20 below the speed limit.
Don't know about in the United States (or Finland), but if I'm travelling long distance in Australia late at night (like this reporter was), your scenario doesn't work at all. There are very few petrol stations open after about 10pm outside of cities and very large rural towns. You have to be very careful about planning your trip in this scenario, so that you can make it to the next petrol station that is open. This makes the scenario pretty much the same, whether driving with an ICE or electric drivetrain. Actually, it's not the same because there are countless more places to "fill up" an electric car in comparison to the number of petrol stations (almost any electrical outlet would do) where he could have spent about 10-20 minutes charging to get those extra 3 miles of range that he needed.
Note this from Wikipedia. The power to overcome drag is related by the cube of velocity.
The power required to overcome the aerodynamic drag is given by:
(Equation at: http://en.m.wikipedia.org/wiki/Drag_(physics)
Note that the power needed to push an object through a fluid increases as the cube of the velocity. A car cruising on a highway at 50 mph (80 km/h) may require only 10 horsepower (7.5 kW) to overcome air drag, but that same car at 100 mph (160 km/h) requires 80 hp (60 kW). With a doubling of speed the drag (force) quadruples per the formula. Exerting four times the force over a fixed distance produces four times as much work. At twice the speed the work (resulting in displacement over a fixed distance) is done twice as fast. Since power is the rate of doing work, four times the work done in half the time requires eight times the power.
This is also true in much of the South Island of New Zealand. Before my first visit, I was told that when my gas tank reached 1/2 empty and I saw a petrol station, I should fill up. I found that to be very sound advice especially while driving along the West Coast.
This doesn't apply to me or my car in my environment. Just because it's true for some environments for some people doesn't mean it applies to even most of the United States.I can easily get rated range in the right conditions ... 65-70mph, slightly rolling terrain, 65F.
I'd have been fine with a fixed rating that I have some control over -- maybe a setting slider between (Ideal+1Wh/mi) and 500 Wh/mi. Some Tesla-controlled number that varies between firmware is and overly optimistic for my driving conditions is the problem.Perhaps it was, I don't think his point was that hitting rated range was important. For me, I'd like a fixed point.
I can "easily" get negative consumption if I define "the right conditions" as downhill Mt. St. Helens.
The other issue is that I've seen what Projected did in the old firmware. It was exactly what I want. And then they took it away with no explanation and no replacement.
That's correct, but when it comes to range it only goes as the square. That's because going faster not only burns more power, it gets you there faster. So cube on the top divided by linear on the bottom equals square law.
Does it seem a little odd to anyone that this journalist would rent a new technology car for evaluation and start driving on fairly deserted highways close to midnight ?
it's not too hard to find a stretch of desert interstate with 20 to 50 mile gaps between gas stations--and the gaps only grow bigger if you need a station that's open 24/7 or one near a smaller two-lane highway...
Of course! Thinking about this though, it seems like it would remain a cubed law WRT wind, as overcoming wind doesn't change distance traveled. Is that true?
unfortunately, that area is not even EV-drivable territory.
