Knightshade
Of course, they can change that design and still achieve L4/L5.
I will note the exact wording quoted above says "can" not "must":
"With respect to redundancy, absolutely you can run basically the copy of the network on both, and that is actually how it's designed to achieve a level 4 or level 5 system that is redundant"
Note as I pointed out in the other comment, SAE L4/L5 specifications do not require the fall back in a ADS failure to be identical to the main ADS, only that it can reach the "minimal risk condition". That means you can run different code in the backup system.
What backup system?
They only have 2 nodes.
They are using BOTH for the primary ADS now.
I also find it pretty grasping-for-strawsish to decide the multiple times Elon, Karpathy, and Bannon all made a big deal out of having full redundancy for FSD were all just "can" not "must" discussions...
The physical design of the chip, at many many specific points, is intended for A/B full failover.
If that wasn't the thing they actually needed the FSD computer would look entirely different.
The HW design makes no sense for anything else.
That they've found they're now unable to get it working is not an indication they just decided later they didn't need it--- a LOT of engineering work went into that as a NEEDED thing-- otherwise you don't get that design in the first place.
It's an indication they couldn't manage it with the compute available.... and it answers the question folks asked back in 2019 of "If HW3 is so great, why did they admit they were already working on a 3x more powerful HW4?"
That answer being they knew they might not be able to do it with HW3 even if they hoped they could.... (just as they hoped it but couldn't with HW2 and HW2.5)
This isn't a failure on Teslas part, so it's weird people keep bending over backward to try and find excuses.
nobody knows how much compute you need for FSD- so the fact Tesla has taken several guesses now, and they've underestimated every time isn't surprising or a failure of any sort.... and the fact they were already working on HW4 2 years ago tells you it's not even THAT unexpected on their end.
And I'd bet you a fair bit of $ HW4 is also explicitly designed for full failover redundancy.
Because you're not getting L4/L5 approved in a lot of places without that. Something Tesla knew, and kept pointing out they were aiming for, years ago.
They still are.
