I swung by late this afternoon to check this out. I didn’t charge because I was in a bit of a rush.
The location is St Johns Rd, near the intersection with Glebe Point Rd. The unit is indeed big, although not much wider than the pole it is on, and appears to have a ground stake, so groundworks to install are not quiet zero:
The power cabling runs straight up the pole, protected by a large conduit for about 1.5m above the unit, before the sheathed cable runs straight up and connects into the 3-phase. The rectangular box at the top of the pole is unrelated to this charger:
There are two 11-kW Type 2 sockets, one each side. I did download the App but have not created an account. Interestingly, the App says it is “Powered by Tesla”!? Does that mean the back-end billing is done by Tesla? Also interesting is that the RFID panel can be yellow for “Reserved” implying it could be possible for someone to reserve a port.
View attachment 912200View attachment 912201
Parking is time limited to 4 hours while charging during the day, but you could park overnight to charge if you wanted to:
The spots have already been painted to indicate EV charging only:
If I have time on the weekend, I might do a charge.
