All,
I'm experiencing an odd situation where I'm getting an audible and visual alert (on the binnacle display) while changing lanes. It happens often enough that I've had a chance to look at the visual bright red pop-up and it says something about a "Lane Departure Warning". This is a very different warning that I normally get when using the similarly named feature located on the "Driver Assistance" tab, which usually amounts to a momentary vibration of the steering wheel. I have the 'rumbly' warning disabled, so this alert may be related to AP or one of the emergency alert systems...?
I can make this alert occur most often under the following conditions:
I normally have TACC and AP on while just burning up the interstate, but due to the very aggressive AP lane changes, I have that particular feature disabled. When I put on the turn signal (usually the left direction to pass a slower car), AP disengages automatically in most cases, and TACC remains on. As I cross in to the left lane, the aforementioned alert sounds quite loudly, even though I've got my turn signal on and AP has been disengaged for at least a second or two. I've tried waiting up to five seconds after AP disengages before actually changing lanes, but the alert still sounds. The only reason I'm bringing this up, is that the rapid high-pitched beeps usually wake up everyone in the car rather abruptly and continue to sound until I finish the lane change.
Is anyone else experiencing this? I thought my turn signal would be enough to notify the appropriate systems that I'm going to be departing my lane, but perhaps this is not the case.
-DJ
- AP2.0, uncorked S75D, April 2017 Delivery.
- TACC enabled and engaged
- Auto Lane Change disabled
- Lane Departure Warning disabled
- Autopilot enabled, but recently disengaged
- Turn signal on and in direction of intended lane change
- Initiate a normal lane change (think Interstate driving when passing a slower car).
-DJ
