Alrighty, guys so I got one side fully functional by tapping into the passenger camera/turn signal on the front fender.
Something to note with these is the video of the Model Y a few pages back has a different sequential pattern than these. The segments on the Model Y video start to fill up the indicator fully as it animates where as these have just one light kind of like Knight Rider. I also was wondering if these had a DIM mode so like when the parking lights are on they would dim down more but that didn't seem to be the case. I went and looked back at the Y model video and noticed those didn't either.
The plan is to finish up the other side tomorrow.
Thanks for posting that video. So, after watching your video and comparing it to several other YouTube videos out there which show these LED sequential reflectors on Model 3’s and Y’s, I have noticed the following:
When these LED reflector kits are installed on a Model Y, they definitely behave/operate differently than on a Model 3.
1. The first difference I notice is when you turn on the headlights on a Model Y, these LED reflectors go through a “start-up” animation sequence that simply does not happen on a Model 3. Take another/closer look at the Model Y video I posted a few pages back and you‘ll see that initial animated sequence performed by the reflectors when the vehicle’s headlights are turned on. This definitely does NOT happen on the Model 3 when you turn on the vehicle’s headlights. Instead, the reflectors simply turn ON and there is no ”start-up” animation.
2. The second difference I notice is what you mentioned in your post from above… the reflector sequential pattern on the Model Y is indeed different than on the Model 3.
The above two differences in behavior have nothing to do with the LED reflector kit itself (all these LED reflector kits are the exact same product… at least the current batch of kits that you see out there right now). What is causing this difference in behavior/operation is how Tesla has wired the tail light on the Model Y versus how they have wired the tail lights on the Model 3. Unfortunately, I don’t think there is any way around this right now.
So, I hope what I’ve observed/reported above helps people understand why they are seeing some of these differences.
Honestly, I prefer the way these LED reflector kits behave/operate on the Y versus the 3. However, not enough to trade in my 3 for a Y!!!
Oh, I do have one final observation. In your video, when you step on the brake pedal, your reflector clearly flashes/blinks multiple (looks like 4) times before the reflectors remain on/solid. However, on mine when I press on the brake pedal, the reflectors do not flash multiple times or at all actually. Instead, when I press on my brake pedal, the reflectors will animate once (like it’s going through one turn sequence) and then turn off. There is absolutely no flashing (quick blinking) of the reflectors. The reason for this difference is you decided not to connect the reflector’s yellow&blue combo wiring to the vehicle’s tail light harness. Instead, you tapped the reflector’s yellow/blue wiring into the front fender side turn signal, which allowed you to get full functionality out of these reflectors (turn signal functionality and brake light functionality). However, after seeing the rapid flashing/blinking of the reflectors every time the brake pedal is depressed, I think the repeated flashing/blinking sequence looks a little odd, especially when your turn signals are activated. Imagine what would happen and how the reflectors would behave every time you make a turn. The reflector will go through its turn signal animation. Then, every time you press on the brake pedal (or release the accelerator pedal to slow down), your reflectors will quickly flash 4 times and then the reflectors go back to its turn signal animation. Not sure about you, but when I make a turn, I usually need to step on the brake pedal multiple times in response to what the other drivers in front of me are doing. So, imagine what your reflectors are doing when you have your turn signal activated and are stepping on the brake pedal multiple times before and during your turn. I think you’ll realize the reflectors go through a rather odd sequence of lights and will look a little odd in how it operates, especially when seen by other drivers behind you. So, I definitely will not try tapping into the front fender turn signal with my kit and just live with no brake light functionality on the reflectors. Of course, this is just my opinion & preference. You may like the quick flashing/blinking effect. Certainly nothing wrong with that.
Anyway, good job on the idea (to tap into the fender turn signal) and your install!
