dark cloud
I have a 2014 S85 and just updated to 40.2.3 and it looks like my regen is pretty much back to normal, or at least much less throttled. The last couple weeks I’ve had almost no regen and limited power around 50 degrees ambient, and with a 10 mile drive I wouldn’t get any of it back, maybe a little.
After this update, I charged to 80%, let the battery sit in the cold for 6 hours, and then turned on the cabin heat about 10 minutes before I left. Same thing I do every day, roughly the same exterior temp. I even preheated shorter than normal and the battery SOC was 80, higher than my typical.
I only had slightly restricted regen and power, and within 5 minutes I had no dotted lines at all. I had 78% SOC, 50 degrees ambient. Before the update I would have maybe 25% regen if that. This update is being pushed out fast to older cars also, which also makes me suspect it has some kind of adjustment. Either the battery heater is working again when the car is preconditioning (maybe a scheduled departure bug messed this up) or possibly they identified cars that need to be throttled ala batterygate and let some of us off the hook.
That is an interesting idea, that maybe the update .36.X.X somehow messed with the battery heating parameters. I hope you're right. I drove on 40.2.3 yesterday but not sure yet whether regen is better.
