The gutter is the grey box below everything. Also called wiring gutters. They are much simpler than multiple conduits to every device.Not sure what do you mean.
I missed that too, but went back and read label.My response was incorrect. Far left is disconnect for batteries and next one with lever is RSD. I had to zoom in and read labels to understand that.
What does REC mean?Yes, the production meter is for REC.
"gutters" ? Not sure what do you mean.
Renewable Energy Certificate. Not available in California.What does REC mean?
Close, it means Rapid Shut Down. It is all about safety for firefighters. If the clutter makes it safer I cannot complain. Remember, just shutting down solar and throwing main breaker will not shut off power to the house. The Powerwalls will just think it is power outage and energize the gateway and the load panel.Is RSD remote solar disconnect?
I cannot believe how many disconnects my plans I am just reviewing are showing. My wall is going to look like .....Close, it means Rapid Shut Down. It is all about safety for firefighters. If the clutter makes it safer I cannot complain. Remember, just shutting down solar and throwing main breaker will not shut off power to the house. The Powerwalls will just think it is power outage and energize the gateway and the load panel.
Better than a dead firefighter. Quit complaining, its not your money anyway, correct?My wall is going to look like .....
Wiring trough is another term that is used. No worries, modern language has evolved. Animals on farms drink from a similar shaped water trough without the cover.troth"/trowth? or something like that
Are those disconnects in your garage, 3, by the batteries? I was told code was they had to be within 3 feet of the MSP?Yeah, that's the attitude Sunrun has. But that position is a fallacy; neither H2ofun or myself want firefighters to be harmed. We just want the designers to put in the system in a logical way so the firefighter can disarm the home rapidly without running around looking for blades all over the house. I contend all these blades are actually less safe.
Here's the side of my house that a firefighter would see when they arrive. Notice the TEG2 has no stickers.
A reasonable human being would think... Let me turn off the main breaker in the panel that has the PG&E meter. And while I'm at it, I'll throw down the big monster 200 A switch. I mean, these are the no brainer conclusions right? Then they'd see another red sticker on the other grey panel on the wall of my house. So this same person may open that up and turn off those breakers too.
So... it's safe right? WRONG. Turning off the things that are labeled with red stickers visible to the main service panel would not disarm the solar or batteries.
So maybe the firefighter reads that red placard and learns that I have 3 batteries in the garage. So they break their way in and flip the 3 blade disconnects.
But guess what, the solar panels are still live.
The firefighter still has to go to another part of my house to find the Enphase 3C combiner, open it up, and turn off the OCPD breakers (no blade!) in there.
So, I think the right answer here is to use the Gateway 2 as a one-stop shop. The Gateway has all generation OCPD breakers in one spot. And as a bonus there's another breaker to turn off the utility power from reaching my home loads. So a firefighter who wants to safely de-energize my home completely (shut down the utility, PV-DC, PV-AC, and ESS) can do so in one place. But Sunrun absolutely refuses to label the system that way, and basically built the system as if the Gateway 2 didn't exist.
To me, putting the Gateway within line of sight of the main service panel is a no-brainer for firefighter safety. Both H2ofun and I are on board with this. If the Gateway had the right sticker placards, a firefighter could walk up to my main panel and the Gateway and make things safe without blade disconnects.
I agree but technology is moving faster than the code can keep up. Before batteries, all a firefighter had to do was pull the meter and then they knew for sure the house was safe. But then someone got hit with 400 volts of DC on the roof and the code evolved into RSD. None of that was coordinated with batteries which could have been integrated with a simple cost effective big red push button, which could be wired to rapidly shut down all systems simultaneously.Yeah, that's the attitude Sunrun has. But that position is a fallacy
I find it interesting because out here (in MD) they installed a single blade disconnect ("fireman's disconnect") which kills both the PWs and the solar (which has rapid shutdown devices installed.) It does not kill grid power, but it is mounted right by the meter. (And, in our area, the meters do not have outside breakers - the only way to kill power to homes from the outside is to pull the meter or, I suppose, to cut the wires.) It seems like this is a reasonable solution, and close to having a giant red button - more like a red label on the meter reminding you to hit the second button.Yeah, there are advocates here on TMC and elsewhere that believe a big giant red button acting as a relay to switch off a bunch of circuits is the right thing. But that's definitely not code compliant.
In the meantime, I think Tesla is doing the right thing by basically making the Tesla Energy Gateway a single place to make things safe (someone just has to be aware to open it up). Maybe the Gateway 3 will simply have a big red lever on the outside instead of requiring people to open up the Gateway 2 cover.
