Does anyone know if I reduce the charging amps, does that also reduce the amount of amperage available for HVAC heating when plugged in? So if I reduce the charging amps to 32 to stretch out the charging of my battery so that when I’m ready to leave, it has just finished charging, and I go to blast the heat on a cold morning 15 minutes before I get in the car, will the heat be limited by the 32 amp setting? Or is that setting only related to charging?
In other words, if it is using all 32 A to charge the battery and I turn on the heat, does it reduce the energy available to charging the battery so that it can heat the car? If this is true, I would want the full 48 A. Hope this makes sense!
