ra-san
Are either or both of these still completely applicable to the P85D? Any new gotchas to consider?
Right, now I remember you saying that up thread at this post. Thanks for reminding. So you still got your original design back on. Aside from install difficulty the mod still looks as solid as with the old joint?I noted that Tesla is now using a ball style joint (yea!!) on the outboard end of the upper link. The joint has a steel outer sleeve and thus the bore in the link is smaller for a tighter press fit. The folks at OpenEVSE may need to change the outer bore on their links (and subsequently make left and right link part numbers) to accommodate the new out board joint. Knowing Tesla, they have likely implemented this change on all product and not just the PD but I have no proof of that.
Only ever got 1500 or so miles out of my AO48s on my roadster, but not going to be acceptable to me to only get a few K on the S. Shooting for 10K plus anyway, 30+ even better, though can't see that happening on 21s with the original PS2s. If i can't get that out of the 21s, will be looking at 20s too, as you have. Just want to get a good baseline with the stock tires, wheels, and tweaked but stock alignment to start with.
Just did a quick scan of the thread but cannot find the settings you speak of.... can you point me to which page has this info? My car goes in for service one week from today, and though it is on the standard coils I'd assume the same alignment specs make sense. My car will be lowered about 1.5-inches all around with the modification to the shock bodies (new c-clip grooves)-- so any thing I can do to the alignment to help long term is great info.
Here are the settings I used:
The front was set to tesla specs
-0.70 Camber
3.55 Caster
-0.04 Toe
Rear was set as follows
-1.00 Camber
0.18 Toe
The rear camber settings would not have been possible without the adjustable links. The shop that did the work got the setting perfect.
artsci,
You must be getting some fantastic wear numbers from your tires as those are some very friendly alignment settings.
Yes, the design is the same and there is "camber gain" built into the design. That is, negative camber will increase as the car lowers. The primary caveat and reason why wear has improved across the air fleet is that Tesla's current "Low" is the original production's "Standard" height. You can not achieve the original production "Low" without mucking with the car so the car does not see the same negative camber values in operation.
artsci,
I had a chance to examine different rear toe values and straight line stability with my previous P+. I learned that near zero toe in on the rear of MS (0.1 - 0.15 degrees total toe in) was very good for range but allowed the car to follow irregularities in the road like rain grooves cut in concrete paving on the interstate. Conversely, higher toe in values (like 0.45+ total toe in) made the car track straight as an arrow but significantly impacted range.
Fast forward to my new PD and things have changed. I am currently running 0.10 degrees of total toe in on the rear and the car tracks straight as an arrow. The obvious conclusion is that the front wheel drive torque is acting to "pull" the car on the interstate thus dramatically improving stability.
Thank you Tesla. I now get the best of both worlds. Let's see if the front motor is the motor of choice with torque sleep so that we can keep the straight line highway stability.
