chickensevil
I made a comment about range before and it was sorta covered here in response to the question by saying that if you had an 800 mile pack then you would be able to get to 400 miles in 20 minutes using current technology. This should be highlighted as my only major NEED for a larger pack as it gives an angle toward getting more miles on the bottom half quicker. Do you NEED more than 200 miles for normal driving? No, not really, but there is plenty of circumstance that you would NEED to get a recharge of that 200 miles back relatively quick (say around 5 minutes). Our current cells can safely handle around a 2C rate max. So if you had a larger pack your C rate is therefore higher, so your 2C max becomes higher thus filling the pack back at a faster rate.
So what they need to do and focus on, is getting charging times lower. One shortcut to that would be the ability to sustain a high kW rate in the pack for a longer period. Even if they *cant* go higher than 135kW, being able to stay at that rate for a much longer period would mean more miles faster. If your taper curve didn't hit on that 135 until after you were at a half charge it would cause a pretty big difference in recharge times.
The final point I would make is that I strongly feel that the better sweet spot is actually 300 REAL miles. Not 200. There is a reason I went with the 85kW pack for my driving needs and there have been plenty of times where I wished I had just a *little* bit more range. I wasn't doing any crazy road trip, it was all just normal local driving, and as it turned out, just toward the end of the day I had to go out of my way to get some extra miles on my car to finish out my day's driving. Maybe this is more of a problem with the spread-out DC metro area.... but it is not uncommon for many people in my part of the country to go north 30 miles, then south 60 miles, and then west 40 miles, (and so forth) all in the span of one day.
Most cars on the market easily have 300+ miles of range on them under most all driving conditions. It is what people are used to having access to. Yes, 2 seater sports cars and other crazy high performance cars are the exception to that, but even most of the large luxury easily have more than 300 mile gas tanks on them.
I am happy with my range, and I make it work for me as my only car, but there have certainly been moments of inconvenience that a non-enthusiast would not be willing to put up with... recharge times and a *slightly* larger battery would fix all of that. I really am nit-picking here though, since it has no real impact on the success of the company, since there is plenty of market for their current cars given their "limitations" just make it cheaper and we will be good. But in the future, I expect we will see 400 mile packs become the standard, and combined with a 5 minute half charge time, and there will be no excuse not to switch by really anyone out there...
