nswfugitive
Your... for some reason can't edit my previous post.You’re
I just called Tesla Support and they told me that it is not a web-server lockup bug, but in fact, they are blocking it!
It's frustrating that we're getting conflicting statements from Tesla about this.
This is a quote from an email I received from Tesla in Australia, after I visited their office.
"As discussed we are still investigating why the web server on the Gateway has become inaccessible to yourself. As a first step we would like to remotely run some diagnostics and restart the Gateway."
I think the support staff reached by phone, who are likely to have the lowest level of techical knowledge, are just misinformed.
If they won't reboot it, you'll have to try to reset it, either by pressing the reset button, if you're luckly enough to have one, or by completely powering it down, including switching it off by the switch on the powerwall, tripping the main grid breaker, and turning off all the solar power. (This of course means that your house is totally powered down too). Wait for ten minutes before turning on again.
I would point a customer agent that claims Tesla is blocking to this page:
Software Updates | Tesla
which recently got updated so the "learn more" link now points to a page which now shows how you connect locally (if your webserver is not hung).
I have access again!
Thank you arnolddeleon for your posts on this topic - very helpful. I have been in contact with Dan at Tesla support for over a week. He tried originally on the 15th to update the Powerwall firmware, but no luck. I emailed him right after you posted this and quoted your statements. Moments ago, I finally have 1.21.0 and local access has been restored. I was told twice by Tesla support that they turned off my webserver. Through my conversations with Dan, its clear that this was a bug. I've waited 7 weeks to get this resolved.
Looks like it's time to dust off the raspberry PI and get my PVOutput.org flowing with better data.
When the system is "hung" they can't login to the wizard either (locally and apparently they can do it remotely as well)
That can't work for a powewall gateway, because Tesla have no way of addressing a device on a LAN from the Internet. So any access Tesla has to the gateway has to be as a result of the outward connections that the gateway makes to Tesla's servers.I wouldn't be surprised if the support group has a way to VPN into the gateway, though.
It doesn't seem like there would be any pressing reason to use the HTTPS port to tunnel a VPN connection. I wouldn't expect them to routinely keep a VPN connection open.
Even when I had no access to the web server, I could still ping it. Indeed, examining network traffic showed that the gateway was responding to connection requests to both ports 80 and 443, was accepting them, and was acknowleging data sent to them - it just wasn't sending any response data.
Your inability to ping or connect from anywhere else in your network sounds more like a routing or firewalling issue than anything to do with the gateway itself. You might want to look at what your dhcp server is handing out in terms of default gateway and network mask.
Regarding the reset button, I took some pictures of my gateway. These are thumbnails.
View attachment 320274View attachment 320271View attachment 320273View attachment 320272
It seems odd that there should be different variants, other than to allow for the lower voltage/higher current in the USA.
