Can you see device vitals? Netzero app can query that for you without much effort. Mine’s empty
I was just upgraded. I can confirm that the Tesla One app using the teg network can see the voltage and amperage of the 4 individual MPPTs in a powerwall+.Tesla made a change in 23.44 that removed the device vitals API, which affects access to string data. Battery degradation data is luckily still available. I'm not on that version yet, can someone on 23.44 try the Tesla One (formerly Tesla Pros) app and confirm that the string data is shown there?
I've been busy moving Netzero app to the new Tesla Fleet API, but once that's rolled out I plan on fixing the missing vitals info. I'm hoping to just use the new APIs that the Tesla One app uses.
Are QR codes confirmed to work on Backup Gateway 1? I have not been successful at scanning my QR code with latest Netzero. In fact I can’t make Tesla One work with it either.The latest Netzero version will get string data and other vitals using the new /tedapi API endpoint (what Tesla One uses). You have to connect to the site controller wifi for that to work -- scan the QR code the first time, then you can just tap a button to connect to the wifi. This should also work for PW3, hopefully someone can confirm.
You might want to double check which QR code you are scanning on the Gateway. There is more than one.L
Only got one, annotated with TPN and TSN numbers
Ah, thanks. Was able to connect to gateway WiFi and access it via manually configuring 192.168.91.1Ah, looks like Gateway 1 might not have a wifi QR code. Do you see a TEG wifi network when nearby? If you try connecting and using the full TSN as the password, does that work? According to this page you might also have to prepend S to it if it starts with TG:
Connecting to Tesla Gateway and Powerwall+ | Tesla Support
If you lose internet or cellular connection, view instructions on how you can monitor your system’s power flow and charge level via web browser by connecting to your Gateway or Powerwall+.www.tesla.com
Interestingly enough, I’m not seeing any extra information in Netzero app, irrespective of which network I access gateway from. I cross checked from 2 phones, where one connected to gateway WiFi and another phone connecting via home WiFi. Certainly don’t see vitals anywhere
Ah got it. Tried it with your suggestion. It seems to be able to connect to gateway WiFi for a few dozen seconds, and then seemingly disconnects without success.Netzero currently relies on a QR code to connect directly to the gateway, connecting manually will not help. I'll have to add a manual flow to make that work, or you can trick it by printing your own QR code here: pure JS WiFi QR Code Generator
