They are VS Forged VS12
Aesthetically you can't tell but coilovers will provide better comfort and also give let you adjust height.What's the major difference between a "coil over" and "spring"? They both provide the same end results right? aka lowering.
Coilover usually refers to the spring-damper combo. Besides continuous adjustability of the height, including the damper in the adjustables makes the system possible to "keep balanced".What's the major difference between a "coil over" and "spring"? They both provide the same end results right? aka lowering.
Hey everyone, looking for a little input on this.
I had my TSportline lowering springs installed on my LR Model 3 single motor 19 inch Sport Wheels and stock tires for a few months now. Loving them! No issues going over bumps etc.
I noticed something since day 1 of having them installed but I'm not sure if its just coincidence. I noticed on hard acceleration or slightly more aggressive turning, the tires are kinda squealing now. It happened right from day 1 of lowering the care with about 13K miles on the Continental stock tires. After 500 miles, the car had alignment done as well and I still notice the same squealing. I also had the tires rotated and balanced after lowering as well within a few days of lowering the car.
Before lowering the car, I never noticed much squealing based on same driving habits. Even a 0-60 acceleration from a stand still before lowering didn't have as much or if any squealing as it does compared to after lowering the car.
I'm not sure if this should be a coincident and that the tires are showing age or if I should be concerned? There's still plenty of tread left on them and I have 15k miles on them currently.
Could be coincidental, could be your driving more spirited, who knows. In theory, tires should squeal less (at same speeds) if the suspension is stiffer because there's less weight transfer, but this would only be at the limit.
Typically after changing the suspension geometry, significant toe-in is introduced to the wheels/tires. Toe-In (or Toe-Out) will absolutely increase tire squealing. Camber will as well, but it would have to be incredibly extreme which isn't the case with the type of lowering springs you used. Alignments are an absolute must after lowering cars or you'll shred through your tires. You said you got one after 500 miles, I'm surprised that didn't improve it. Did they give you a pre/post alignment report? How confident are you that they actually properly adjusted the toe? I'd inspect your tires for unusual tire wear, most notably the inside.
Causes and types of tire damage | Continental tires
Check out the tire wear guidance on the above site.
IMHO, lowering springs are for looks only....the driving dynamics change with lowering springs and not for the better....granted I am used to coilers and very stiff cars but with lowering springs, there is till significant body roll and it appears more bouncy heading into corners hard...some of this may be the increase in understeer I am feeling since going with 20 x 8.5/10 staggered wheels and tires.
Looking good! It's hard to believe how much of a difference 1 inch makes!Finally got around to taking a better shot of side profile of the drop. Lowered on TSportline Springs (1 inch drop).
Perfect for daily driving and no issues with curb blocks or incline driveways. I just drive normal abe a little slower just to be safe. Handles great and I just love the look and stance.
It's hard to believe how much of a difference 1 inch makes!![]()
So what happens if you are on an expressway, run over some debris, damage your 20k battery and insurance adjustor finds out you had your car lowered?
Love them. The ride and handling is great as expected. Although I still need to go back to UP to have them inspect everything. Been hearing a faint squeaking noise after the installation.How do you like your UP coilovers?
How do you feel with those TS lowered springs?
I've been debating between those and UP Mild for the longest haha. I have a RWD Model 3.
