a model s 85 only gets 200 miles of range at 70mph? :O
I have found achieving 200+ miles on the P85D doable, but more difficult than on a P85+ with single motor. Range mode is a must. Changing your speed from 70 to 65 actually makes a big difference. However, arriving at an SC with 2 miles is a badge of honor.
IIRC, I arrived at the Dalles, OR supercharger opening with 2 miles rated. I got mostly positive response to that.However, arriving at an SC with 2 miles is a badge of honor.
@Candleflame
It's more complicated than that. As the OP expressed, the superchargers were not 26 miles apart; so had he slowed down to a speed less than 70 it could have taken less time because a 100% charge may not have been necessary. The last few % take a long time, longer than slowing 5-10 mph. Spend an extra 15-20 minutes getting the last few miles charged, or start driving sooner and drive slower.
I posted some charts here: Optimum Supercharger driving speed, you can see at higher speeds (especially longer distances) you dip deeper into the charge taper.
If your superchargers are 26 miles apart, the optimum speed is probably about 110mph; but you'd still only save about 1 minute over going 85. (Going 70 takes about another 4 more minutes.)
In distances you're likely to find superchargers, 80~140 miles, the difference of 10mph less than an optimal speed only means a 5 minute loss after charging. Not a big difference for a 2 hour drive.
This is an update to this thread. I did the exact same trip. The first time was on firmware 168 and now I am on 245. Exact same config except this time I had a fan running in the back for the kidos which did great to keep them cool. the temps were 10 degrees warmer. The trip down was from 7pm to 3am and trip up was 11pm to 6pm.
Stopped at both country club hills supercharger and effingham.
This time around i did less cruise control and more me, but I let the cruise do some work and it was doing the same that I was doing really.
I was able to go 75-80 mph to effingham and have 15% left. I averaged 330-340wh/mi going 10-15mph faster. This was a shocker. Last time I barely made it with 1 percent gong 65-70mph. I thought it was a fluke and tested it on the way back. Again charged actually only to 98 percent in Effingham (a bad storm was coming and wanted to beat it... that last few percent was taking forever) Arrived at country club hills, IL with 15 percent charge doing avg 75-80mph and got ~340wh/mi. Was there an improvement in sleep mode from 168 to 245? I mean I didnt even have range anxiety at all this time. The 1 percent last time left me pretty nervous but proud I did it at the same time.
As for the routing of the supercharger, it still wanted me to go to normal, IL... way out of the way for the trip.
Thought I'd give an update to this.
That sounds pretty typical. Warn are is not as dense so there's less aerodynamic resistance. Also the tires are less stiff at the start.interesting theory. I know the 10 degrees warmer can make a difference but I didnt think it would get me 15 percent more.
I had rear facing seats in my P85. Kids didn't like them after novelty wore off.
The rear seats are a HUGE failure IMHO and I wish I had not gotten them. Too hot, space taken up, and yes ... a novelty.
