Take some more pics tmrw! I am considering your exact setupReady for the first race day tomorrow
In Formula 1, some teams like Ferrari and Red Bull have gone to matte finishes to save weight.What color requires least coating? Could make for interesting weight saving.
Silver 18x8.5 finally mounted. Installer had no issues. Put on CrossClimates to support the work driving. Now I just need to find some Tesla Center caps that fit the wheels.
Took it for an initial spin. Still corners on rails, little more tread growl at some speeds that the PS 4's, but I need to get the tires broken in.View attachment 565686 View attachment 565687
How did it go? About what tire pressures do you run? Did one charge last for the whole event?Ready for the first race day tomorrow
If it has to be all season, consider getting Continental EXTREME CONTACT DWS 06, the are really good in my experience.
If you can get by with summer tires, the Michelin Pilot Sport 4S are second to none.
Summer tires generally have best in class dry and wet traction (Summer tires does better at rain then all season tires)
The issue summer tires have with freezing (or well, below 44f) / snow is not the threads or shape, its the actual material they are made from, it simply doesn't do well at those temperatures.
Most guidelines I read say that if at any point your tires are below 44f even in storage ... you shouldn't use them until they warm up for 24hrs, so if your garage dipped into high 30s over night, and outside is low 60s, you should still not use summer tires until they had 24 hours above 44f
Thanks for your advice. I am also going to keep the stock 235/35ZR20 92Y Pilot Sport 4S summer tires that came with the car, so I am interested in the 44°F guidelines. Could you please provide a reference link?
During my AutoCross days, we kept the Hoosier slicks in the basement during winter to protect them.
Great to hear. Do you run the same classes as SCCA?First autox event with the Martian Wheels and RE71Rs went well! Ended up third overall in raw time and second in PAX (behind a nationally competitive S2000). Car felt great, just need to work on my driving. View attachment 567852
I think if you boil it down, under certain temperature the material a summer tire is made from gets so stiff it loses all flexibility and can easily break instead of bending. If unused they would probably be fine, I'm assuming your basement stay at reasonable temperatures (45f and above?)
As for links, if you google "summer tires cold temperature" you could find many, ex: 1, 2, 3, 4, 5
Yes I'm running in SS. Had the tire pressures around 40psi hot. Think I will try a bit lower pressure at next event. Still waiting for my Eibach rear sway bar to arrive.Great to hear. Do you run the same classes as SCCA?
Thanks for the thorough response. There is also a TMC thread:
Where to store summer tires?
You would think that this danger of terminal cracking would be mentioned in the Tesla M3 manual or on the tires themselves.
My basement stays above 60 F year around, but it's a PITA to move tires down/up there, more so at age 76 with arthritis. My wife is after me to get rid of the old racecar tires still down there as she takes over more of the basement for quilting.
My stock 20" performance tires tires are labeled PILOT SPORT 4S TO. Obviously 4S does not mean Four Season. What does TO mean?
In Pilot Sport 4S TO the 4 means 4th gen as its Michling's 4th gen tire, the S sets it apart from the cheaper "Pilot Sport 4", and I have no idea what's the TO about.
Edit:
1. Looks like you are doing the right thing / most optimal thing, 60f is great for the tire's health. Just make sure not to remount them before the nights go above 45f too
2. Maybe get a wheel dolly for the non stairs portion of the way? as for the stairs, slow and careful ... or grab a neighbor/relative to help, its like twice a year not every tuesday
3. Here is a link reference to what I wrote above about the 4 and the S - link
4. I checked the other thread, that Tire wall mount seems nice, if you get it, maybe install it at waist height so its not so hard to use?
Yes it is, don't know the brand. Most detailers do that now. Makes cleaning much easier.Is the Glasscoating a ceramic type of protection you applied?
“T0” is a Tesla specific version of the tire. It should have acoustic foam, and may have a wider contact patch than the 235-size would normally suggest (it was 8.8” on my 235/35/20’s; my new 235 pirellis are only 7.4” at the contact patch)
Yes, T0 is a Tesla specific spec. A standard 235 tire has a much smaller contact area. Expensive tire by the way.
Thanks. We have a walk out basement so I can roll the tires one by one outside to avoid steps. Then I have some dollies made from 2'x2'x3/4" plywood with casters at the corners, which accommodate a stack of 4 mounted or unmounted tires in individual garbage bags.
I had planned to sell the 20" wheels and summer tires as many have done, but my son, who is likely eventually going to inherit the Tesla, thinks I should keep them.
Thank you, I did not know that, but it does make sense given that the foam is made by tire maker and not Tesla. I wish more tires came with that kind of variant (foam, contact area).
Sounds like a good arrangement, so your dollies are like a homemade version of this product? Would your wife give you easier time if you used this two products while wheels are stored?
Also, the 20" are nice but very susceptible to pothole damage, are you / is your son planning to race the car at a track?
