Well, slow charging, as a WC or any AC charging(max 11kW = 1/7 C) is very friendly to the battery. Litihum batteries do not like to be charged when the cells are sub freezing, but that will be taken car of by the BMS. The battery will be heated to non freezing levels before charging.
I can not se any risk for the battery by charging ”later”. I charge like this always, except SuC, and after 30027km I still have full range, and virtually no degradation. There has to be some, but it do not show right now. If it wanst good for the battery I probably wouldnt have no decrease in range.
But if it is sub freezing temps and the car need to be charged witht the supplied travel ”charger”( ”UMC?), it will take long time to heat the battery if it has cooled down. In that case charging asap after arrival is recommended.
SuC/fast charging = much better at higher temps, 40C or more.
Normal charging, as long as it is not below 0C, its good.
