Yes, because I believe they may allow higher current there.Does it need to be a us M3P?
I know. Would have asked you directly anyway, but feel free to check, were yours is peaking.( I have the 2170L and android)
Oki, I’ll do a check.Yes, because I believe they may allow higher current there.
I know. Would have asked you directly anyway, but feel free to check, were yours is peaking anyway.
Topped 1320 at about 75 kph (47 mph)Any US M3P 2021 or 2022 driver around, who is using Android based Scan My Tesla?
I would like to know what your cars maximum Current (Amps) is, when accelerating through 50-60mph.
European (Panasonic) cars stop at 1240 Amps and only increase slightly above that, when the SoC is getting very low.
If you can, then check again with high SoC and temperature. I would be surprised if you see more than 1240A then.Topped 1320 at about 75 kph (47 mph)
Then decreased and 1304 at 50mph, and 1287 at 60mph(96kph).
Latest Android SMT, 50% SOC.
Car has been sleeping for 2 1/2 weeks when a was in US molesting the Model S Plaid (), battery not really warm. I would guess a higher batt temp would give more power, maybe more Amphs…
So .....tell us about the MS Plaid....would you trade your M3P for one?Topped 1320 at about 75 kph (47 mph)
Good to see AKEE. I still follow your charging recommendations and keep it around the 50% mark as max.I rather keep my M3P also
I did a degradation test today. Drove from 100-0% ( actually ended up at 0.41% according to SMT).
75.15 kWh drawn from the battery, 0.41% = 0.3kWh left, and buffer 3.5kWh.
So the capacity is really 78.95kWh, still after 46K km.
We would not like to trade that M3P away, do we
Preserving the battery with low SOC works (and it works just as the researchers say it should)
I once saw a graph show degradation stress on the battery depending on SOC. It showed actually a wide level of SOC where degradation is low and then exponentially increasing in both ends of the SOC range. Does any one have a picture of that?
Except during our summer holiday where I charged to 100% or close to a couple of times but only while using it at once almost. driving in Europe.
At fully charged at least according to the screen (display in kilometer) I dont seem to have lost any range at all
There had been a delay in cars.What battery packs is the EU market getting on M3P's from Shanghai?? end of september im expecting my m3p
Is it the 5L LG?
Anyone had any recent delivery can comment?
Yeah normally i should have had it delivered in June. Now its September. Hopefully, i ordered on MarchThere had been a delay in cars.
I know M3P MIC should get the 5L but I havent seen any yet. Early in the year the M3P’s still did get 3L, Panna 2170L 82.1 kWh
5L is the 78.8kWh LG.
I’m sure our friend @eivissa knows!What battery packs is the EU market getting on M3P's from Shanghai?? end of september im expecting my m3p
Is it the 5L LG?
In Europe there was a hard cut from Q1/2022 to Q2/2022.I’m sure our friend @eivissa knows!
Thank you @eivissa for clearing it outIn Europe there was a hard cut from Q1/2022 to Q2/2022.
Q1 was still the Panasonic 3L 82kWh that we knew since the Refresh Q4/2020.
Q2 onwards we get the LG 5L 79kWh pack.
Now all Long Range and Performance Model 3 and Y get the same battery pack.
But the picture confirm your recommendation of stsying below tje 57% SOC.I guess you are thinking about a graph made by @Zoomit here on TMC?
I wont post the picture or pictures (it was at least two versions) as they is not in line with the research.
There was a thread where @Zoomit asked about battery stress and from what he was told in the thread, he did write a chart over ”battery stress”.
There was (is) a user that used the nickname EV-tech Exp, but some of the parts he told does not go in line with the research reports.
No bad feelings for @Zoomit at all. He didn’t know, asked and then summarized what was said in a picture.
For EV-tech Exp, he probably did his best to contribute but the end output that rendered a non valid picture ”accepted” that now cause people to have the wrong idea of battery stress at both 70-80% and at low SOC is not very good as I see it.
In the end, that picture is all over the net and I think this it is the 10th time going over this.
There was a lot of research data out and accessible at that time so we already did have the possibillity to know that it does look like this:
Zoomits picture:
Battery Degradation Scientifically Explained
The thread:
Before surfing to these, please remember that the pictures does not reflect the reality.
Feel free to compare the faulty drawing with the researchs dito.
Did you read this post ( MASTER THREAD: 2021 Model 3 - Charge data, battery discussion etc in all, and did you look at the link with Zoomits picture?But the picture confirm your recommendation of stsying below tje 57% SOC.
I saw a graph once indicating high degradation at very low soc (increasing below the 20-25%) and at high, increasing from 60%ish whereas almost flat between these
It's just different with Pro's and Con's...Is this a good change or a bad one??
Since you didn't mention charge/discharge performance I am gonna mention it here:How does the LG 5L compare to the Pana 3L?
Not scientific, but it is notable that the LG packs still show a very high rated range. Even with high mileage, high DC charge and parked long times at high SoC. The Panasonic gained the nickname "Diva", because even though its initial capacity is higher, it tends to punish the drive with rapid decrease in capacity (mostly calibration, not degradation). This can be:1) battery degradation / life expectancy
Only on paper...2) LG seems to have a lil bit less range?
Panasonic is NCA and the LG is NMC. Both chemistries will degrade faster if charged above 60-70% daily and kept there for longer durations, even worth if stored in a hot environment (@AAKEE 's chart looks spot on to me!). Above around 95% it gets especially damaging as this is when the voltage curve increases exponentially.3) if its more "safe" charging to 100% (the LG compared to Pala) since i read its also different chemistry
