I’m also picking mine up on the 19th and they told me that I should get it since it’s a Q2 car (made in April) even though my VIN is 942xxx. I’m really not sure if they can say for sure since they might not have enough information though. Do you have a VIN?A Dutch Tesla dealer contacted me recently about my question whether I'll receive the updated WLTP range of 614km for the Longe Range AWD. The answer was positive: she checked and I should get the updated model when I pick-up the LR at May 19th. Alrighty then!
As I told you last week, all better values I had in my old LR 2019 on Nominal Ful Pack was in Winter .My Nominal Full Pack Value started to increase a few weeks ago.
Starting at 80.6kwh, and topping 81.1 a week after delivery it decreased to 80.1kwh which it held from middle of january until April 6, then it started a steady climb with about 0.1kwh every day.
I have been away on work for two weeks with the exeption of one day in the middle, also increasing that day and today it says 81.4kWh.
My guess is that the higher( well, at least less low) temperatures have an impact on the nominal size. The garage has held + 10 to 12C during winter and is a few degrees warmer now.
Anyone experiencing the same behaviour?
Can the delta between full pack when new /82.1kWh and the usual 80.5-81.0 be explained by the cold weather that prevailed from first delivery of the ’21 P ?
The LG packs were never put in cars intended for the US. Only EU and even there they stopped using them from the 1st of April.Is there no information about the battery in the cars made in US? I want to order a M3 LR but do not want to buy one with these LG batteries. Thanks.
Yes. SMT feeding all its data via Could Service to my home server running Teslalogger.Is it SMT values?
It actually is. The best way to test it is to drive 100% down to true 0% and see how much kWh you get out of it.I’d guess the app is nit the best source to the range or battery degradation.
I see. I assume this is just an educated guess though. It is quite possible to get 82kwh battery with the long range but stay software locked forever. I assume Tesla would not unlock these cars since older LR users might be angry. However if Tesla were to sell an improved range Long Range, they would probably increase the price.The LG packs were never put in cars intended for the US. Only EU and even there they stopped using them from the 1st of April.
Personally I would wait until Tesla starts advertising the Model 3 with the new / higher range. I expect the long range to go from 353 miles EPA to 365-370. That would be the confirmation of the 82kWh battery pack.
This Nominal Full Pack graph shows all changes from the day Ive got the new car until today. 4,5 months in total.
Full Rated Range in SMT is a value that is calculated within SMT I believe. The Range Report in Teslafi is a different value reported by the car via Tesla API to Teslafi.
The most useless value is coming from the Tesla app when sliding the charge limit all the way to the right!
Do you charge to 90% and let it down to 20% due to long drives or lack of charger at home or is is by own choise to do 90-20% cycles ?The car is always parked outside and gets charged to 90% when it reaches 20% SoC. 9500km ODO / 5 Months old.
So you basically did the 60% daily charging tactic which is supposed to calibrate the BMS to the highest possible nominal full pack. No surprise your values are this good ;-)Do you charge to 90% and let it down to 20% due to long drives or lack of charger at home or is is by own choise to do 90-20% cycles ?
Asking because a lower charge would cause less degradation from calendar aging as it also would if using smaller DOD( depth of discharge).
Im not worried you will go below 70% in 8 years but you might be able to see less degradation with another approach..
Probably not the reason for seeing lower NFP than I do, but still something to consider in the long run.
I have a quite different approach, if not the temps do the difference, as conv90’s experience suggest, maybe its the charging habits that do? TimothyHW3 also suggest charging could make the difference.
I did charge to 80% during the coldest month when we daily had -15/-20 or colder. Lowered the charge to 70% when the temps came up a little and 60% when it got warmer( maybe more right to say even less cold). Recently I set it to 55%. My charging scheme at home is to start charging so the charging is complete about an hour or two before I leave for work.
I charge every night, always connect the charger when I park in the garage.
Weekends, then it mostly get charged first night an then not that much driving( covid-19 style). It would be theoretically possible to stay at lower SOC during weekends but it might/would have an impact on the freedom to drive at any time.
Picked my M3P up 30th december and it has 8540 km on the ODO. Manufactured Nov 17 -20 so its 6 months old.
Welcome to the Tesla world of gradually hiding the buffer every 100km. For every 100km you get 5km rated less until 0%. Then you have the other 25km as a buffer. All explained here.EVEN if I stay under the 159 Wh/km constant.
The Q2 Long range with the 82kWh will most likely not be software locked. Certainly not in the EU and I wouldn't know why they would start with that nonsense in the states.I see. I assume this is just an educated guess though. It is quite possible to get 82kwh battery with the long range but stay software locked forever. I assume Tesla would not unlock these cars since older LR users might be angry. However if Tesla were to sell an improved range Long Range, they would probably increase the price.
This does not seem like a big deal to delay my purchase. But potential federal tax credits on the other hand is.
Did’nt know 60% triggers the BMS to show higher valuesSo you basically did the 60% daily charging tactic which is supposed to calibrate the BMS to the highest possible nominal full pack. No surprise your values are this good ;-)
I live in the city center and have no private parking. My car is parked at a different place every night with no private charging available. I know the battery would love to stay in the 70%-30% window to have the least wear, but it makes no sense for me to do that. I have a fixed rate per charge on the public chargers, so it makes sense to have a high SoC delta (40% upwards).
What I always do is preheat the car/battery pack, before driving off. Also no high power demand before the cells have reached at least 15°C. Other than that...I have 30km of unrestricted Autobahn on my way to work and back and I didnt buy a Performance model look at my energy tab all the time...if you catch my drift ;-)
