"I don't agree with you, here is data to support my position"
This was the question:
Again, no offense, but...as someone who:
-doesn't drive that exact car.
-doesn't drive a car with the same cell chemistry and BMS limitations.
-got his information on this scenario from a video of someone driving that car on a different software version.
...I really wouldn't bother answering this question at all.
You do anyway, well...
Reading your lines you must be talking about the smt value "battery max discharge".
Why would you even do that? That value is completely wrong on the Model 3 Refresh.
The SMT developers are aware of this and are working on inserting new tables.
"here is data to support my position"
You were talking about the left value, I was talking about the right value Battery Power at 100% throttle. No less.
So you cant "disagree" and then talk about completely different values. I was talking about your "when I kick it" values all along and that was 78hp / 58KW at 12% SoC and 16°C Cell Temp Mid...reaching 135kph eventually.
SMT / battery power doesn't know what wheels are fitted to the car.
Added weight??? The Performance is 1Kg heavier than the LR...1KG.
Again, I could barely maintain highway speeds at 12%SoC where with my 2020 Performance I was never stopping at Superchargers before reaching 5% with no heavy power reduction like the refresh is suffering at the moment.
This can be fixed with software, surely, but the question was...has it yet? The answer is...sadly...No.
Are there still limp mode issues on low SoC on M3P 2021 with version 2020.48.35.5 ?
Is the heat pump diversion issue solved?
Also the 80kW is what SMT shows, but I can pull more.
could do 80kW if I kicked it.
Disagree, I was at 1% at 55kW max kW shown on SMT (but when I kicked it it went to 90kW)
Maybe the Performance suffer a bit too much because of the wheels and the added weight.
So as a general rule of thumb, just don't go expecting highway speeds at below 5% with a P in cold conditions
