You can run them all in black if you like. It can save a lot of money to buy just one large spool/package of black instead of smaller lengths of different colors. Just mark the neutral white and the ground green at both ends as noted above. You can mark one of the hots red if you like, but it's not really necessary.
For code / inspection, if 6 awg or smaller, the ground has to be green or bare and the neutral has to be white or gray (with any color strip except green) or any non gray color with white/gray stripes
If 4 Awg or larger you can use black wire, but the neutral and ground need to be tagged as such (with marker, tape, etc)
One option would be to use an 6-50 or a wall connector and not bother with a neutral at all. And you can just pull a 10 awg ground which should be considerably cheaper than the 6 awg hots. You can also ground to the box and not pull a dedicated ground wire if you’re using EMT all the way through, but I’m not a big fan of that practice since there’s more to go wrong.
