AZ Desert Driver
Rare combination
I have 8.0 on my 60D and have charged 100% twice - once on 10/21has no one else had the opportunity to test 8.0 yet?
Yours is roughly what I saw without max battery at the same-ish SoC on 7.1.
yep. last time i managed 483, same %, same not ready state.
I'm on 8.0 with a p90dl v2. Got 490kw today at 99% soc with max battery. I don't think that is limited, but could be. It seems 20 kW down from the highest reported...
That's about where I am on 7.1.
Just adding a data point for the P85DL without max battery power.
446 kW at 88% SOC.
Looks like that first run at 75% was with a battery well below optimum temp since the power is significantly lower than other reports. The good news is that the 100 SOC run at 564kw is right on the top performance line.
Here is my run:
2016.5
P100DL Model S
75% SOC
Ludicrous ON
Max battery power ON but still 20 min left of heating
Max Power: 512 KW
- And here are my run specs at 100 soc and max battery power ready. Ludicrous+ OFF. 18 degrees F outside.
- Max Power: 564 KW
Hi all,
Ran some testing on my P85DL today and yesterday. At 25min to 'ready' and 92% SoC, I get 393kW. At 'ready' and 88% SoC, I get no more than 410kW.
Any thoughts? Should I call the Service Center asap? Seems my Ludicrous mode car is not achieving anything better than before the upgrade!
Hi all,
Ran some testing on my P85DL today and yesterday. At 25min to 'ready' and 92% SoC, I get 393kW. At 'ready' and 88% SoC, I get no more than 410kW. Seems something is wrong, as this car should be doing closer to 480kW, at least based upon the logic that the original Insane mode would pull 1300A/416kW and Ludicrous mode should upgrade it to 1500A/480kW.
I used both PowerTools and TeslaLog. Here is one of many TeslaLog plots showing the same thing:
Sounds like your L fell off. I'd try it again at 100% SoC and also contact Tesla.
Hi all,
Well, at least the display offers Ludicrous option and they added the underline to the back of the car! I do feel like the car *was* faster before, ie immediately after the upgrade...A P85DL will not reach 480kW. 450kW will be about the max. As for getting 410kW at 88% with MBR, that is just what you would expect for Insane mode. Are you sure Ludicrous was enabled?
