Now that I'm getting less charge from PV as the days shorten, I find that I'm running out of Battery in the middle of the night and the house is switching to grid. During the day, by the time PV stops producing I'm at approximately 50% of battery SOC. I'm on TOU4-9PM SCE plan and in winter the charge from 9PM to 8AM is slightly higher than 8AM to 4PM. To help compensate for this, I tried setting my reserve to 75% at 8AM to charge the system from PV and then set reserve back lower (5-10%) at 4PM to both raise the SOC of the batteries and utilize stored power overnight. The issue I'm seeing is that the battery will max out at 3.3kW charge rate from PV and begin to dump any excess PV greater than 3.3 into the home (the rest comes from the grid). Is the normal behavior that others have seen? My goal is two fold : reduce/eliminate grid use overnight and let the PWs charge to a higher level SOC. Any insight on other's experience is appreciated. Thanks
