steveho
I had to replace it 7 years ago (moved into a Pacific recalled panel) and now am maxed out at my panel because of my recent kitchen remodel. Adding induction cooktop and convection oven and more lights maxed me out. But the breaker that controls the outlet now used to control my old dishwasher and now only that outlet so it could go several ways. I put an upgrade on my budget sheet just in case. Closest super chargers to me are no where near my commute. Not even in the same city for that matter, so proper home charging would be very important to me.
Thanks. I was going to try them too. The Tesla is an estimate pending inspection, but the car is in great shape so the inspection shouldn't change it much if at all.
Note that you need a double breaker slot for the Tesla because you need 240V. So if you are maxed out, and the only one left is a single breaker, that's only 120v. You may be able to double up some lighting circuits and free up another breaker slot for the 240V one you need for the tesla. It should be a 240V at 50 amp breaker. That should run to a NEMA 14-50 if you are going to use the mobile charger that comes with the car. If you are going HWPC, then you can go to a 240V 100A breaker or 90A breaker, although I have never found that I needed more than the 50A because charging overnight for 6+ hours always gives me a full charge anyway.
