If you are referring to the front then you could not be more wrong.
Set initial spring preload.
Set height using shock body.
Dial in pre load to change corner weights. (using scales.) This is the main benefit with this design - Adjusting corner weights without changing ride height.
Changing the preload on the front to adjust the height is terrible. to lower it you would have to have the spring loose. Then you are defeating the design and losing damper travel.
I’ve asked this myself on the previous page of this thread. Redwoods stance is to adjust by preload....the design does allow you the option to adjust free length...at user/installers risk/discretion.
So we have both available to us... preload AND free length. Both can lower a car, but in different ways - letting the end user/shop set the car up more optimally for the intended use. Now for liability reasons - because the battery is the lowest point on the car - we *ONLY* officially recommend using an OEM free length and adjusting height via the preload on the spring. By adjusting height with spring preload we fix the maximum allowable distance the battery can get to the ground (the bump stop is at a fixed point, and to lower the car we throw away compression travel - but for very low cars this reduces your amount of available compression stroke). If you want both a very low car AND a lot of compression travel, you now need to allow the battery to get closer to the ground at maximum compression. Obviously as your battery gets closer and closer to the ground, you increase your risk of damaging the battery - which is why we officially do *not* condone reducing free length shorter than stock. However, that option is available *at your own risk* should you want to maintain compression stroke and lower the car as well. Basically at a certain point the bump stop needs to come in to stop the car from bottoming out - but with Batteries being the lowest point of the car - you will need to weigh the compromises between how low you want the car and the handling performance (staying off the bump stop).
Our official position is, we will provide a conservative free length for the shock in the install guide, and we only recommend lowering the car using preload. But, additional options are available by sacrificing battery to ground clearance at your own risk/discretion.
Please see the above post, but, it doesn't need to be any more complicated - we provide a single recommended free length top of upper shock mount to center of lower bolt hole, and to adjust the height of the car you can simply change spring preload. However, there are additional adjustments should you want to tweak further - but at you/your installers' risk/discretion.
