@P3D-R My front dampers are at Redwood's recommended length, which is the same for any ride height. They were preassembled that way, I measured to verify of course. Redwood recommends adjusting ride height only via preload. My understanding - which could be wrong! - is their recommended damper length ensures a minimum height under compression that's about the same as stock suspension (regardless of static ride height so long as you only adjust that via preload). Thus avoiding any increased risk of battery-to-ground/debris contact.
For the divorced rear Redwood has two recommended damper lengths depending on ride height, and the rears were preassembled for the shorter length they say is safe for any height (including lowered). For higher heights like stock height, where I'm at, they say it's safe to extend the rear dampers another 15mm. I attempted to do this and for some reason failed to, the whole damper body kept turning, so the lower section never unthreaded further from the upper gold colored part. I was afraid to clamp the upper section to keep it from rotating, didn't want to risk damaging anything, and it was clear that the shorter length was perfectly safe, so I ended up leaving the rears that way. I therefore should have another 15mm of "safe" rear compression travel to be gained, per Redwood's recommendations, whenever I feel like revisiting this again. Which I will at some point. (I did try calling Redwood for advice when I got hung up on this but it was a Sunday, easter Sunday specifically, and they were closed.)
With all of that said...the only time I've felt it clearly hit the (rear) bump stops so far on the new suspension, was over a big dip where for sure it would have hit them with the stock suspension too at the speed I was traveling. The kind of dip where someone helpfully spray painted "DIP" as a warning to not go so fast and destroy your car or crash your bike on it. It was WAY smoother over that dip than it would've been stock, but I could still tell the bump stops got involved.
I don't think the Model 3 is challenged for travel compared to a low sports car or such. My main comparison point is my old Subaru WRX STI, long gone from my ownership but never forgotten. I'm pretty sure it had more travel and ground clearance than most sporty cars. I don't recall hitting its bump stops as easily, and I would tear up these same roads in it, when opportunity allowed. Maybe I'm remembering it through rose colored glasses though!
