Model 3 Frunk Daily Users: Dent Issue?
Discussion in 'Model 3: Interior & Exterior' started by Dre78, Apr 26, 2019.
For those that use Model 3 Frunk on nearly daily basis, do you have a dent/crease?
  1. Yes
    0 vote(s)
    0.0%
  2. No
    22 vote(s)
    100.0%
  1. Dre78
    Dre78 Supporting Member
    Chicago, IL
    Given Model S issues regarding Frunk: Frunk Dent (Frustrating...) I was wondering if the Frunk dent (or Frunk crease) is an issue with Model 3? Has it been addressed somehow?
    Do those Model 3 owners that use Frunk daily have the same problem as Model S owners? (Do new Model S owners still have this issue?)
  2. spleck
    spleck Member
    TN
    They warned me right up front about how to gingerly two-handed close the frunk so I've always done that, but have to keep a cleaning cloth handy since it definitely leaves prints constantly...
  3. buyehara
    buyehara Member
    Honolulu HI
    Yes, I originally thought for the Model 3 I could do a one-handed close by pressing the Tesla logo, but the manual recommends using two hands next to the Tesla logo, NOT on the logo. It can be a bit of a pain if you only have one hand available to close the frunk.
  4. reheat
    reheat Member
    I don't use it everyday but do use it when I take out food. I use the two hands methods and haven't encountered any issue.
  5. buyehara
    buyehara Member
    Honolulu HI
    same here, usually use if for take out food, it does not smell up the inside of the car!
  6. Dre78
    Chicago, IL
    i1Tesla has the solution! Reduced spring tension
  7. Bobbo8
    Bobbo8 Member
    Penfield, NY
    Great fix! Where can I get the springs?
  8. BulletToothWoo
    Denver
    They look a lot like the springs used to hold down the bridge on an electric guitar. Wonder if you could use ones you buy from guitar center?
  9. v8eater
    v8eater Member
    Lusby, MD
    I tried to order via his link but they are out of stock. I’m headed to my local HD. I think they have one. I’ll let everyone know if it works.
  10. mcorf
    mcorf Member
    Campbell,Ohio
    Sounds good.
  11. hcdavis3
    hcdavis3 HCD3
    Hey v8. At HD, how do you know which spring to get? Did you take out the stock spring, get one the same length but lower tension? This sounds like a great way to easily close the frunk.
  12. v8eater
    v8eater Member
    Lusby, MD
    I just matched it with the one he linked. Making dinner currently. I’ll go out and install after and provide feedback and the stock number etc.
  13. Eno Deb
    Eno Deb Active Member
    SF Bay Area
    This looks interesting, but I guess there must be a reason why Tesla used a stronger spring?
  14. hcdavis3
    hcdavis3 HCD3
    Thanks v8 you’re awesome. Enjoy dinner.
  15. v8eater
    v8eater Member
    Lusby, MD
  16. hcdavis3
    hcdavis3 HCD3
  17. Tron 3
    Tron 3 Member
    Colorado
    I took the spring out, clamped the hook on one end in a vice and heated the spring with a propane torch (just enough that water would sizzle, but hot enough that it would burn you instantly if you touched it), and then quenched it with a wet towel. Effectively "Drawing a temper" on the metal, softening it slightly so the spring stretches a little easier.
    "Tempering" is when after hardening the carbon steel it is reheated to draw off a degree of the hardening. Now the spring is the original dimension but slightly softer. I reinstalled it with my fingers, where it took pliers to get it off. I can now push the hood latched a noticeably easier, and with one hand - not getting close to bending the sheet aluminum. ;)
    I feel better having a stronger spring than the lighter gauge one he replaced the original with.
    • Informative x 3
  18. KenC
    KenC Member
    Maine
    It's a screen door replacement spring. You can pick up a replacement at HD, or other DIY center. Like hcd, I've ordered one at my local HD, for pickup after mom's brunch tomorrow.
    Perfect timing, as I just put PPF on my hood, so I'll be using my frunk a lot more now. The smelly lacrosse equipment is going to go in there, gloves, cleats, socks...
  19. KenC
    KenC Member
    Maine
    Just installed the screendoor replacement spring that I got at HD. It's the best hack ever. Now, the frunk opens and it doesn't sound like an explosion, and it closes so easily, no more fear of bending anything.
  20. MoHazee4
    MoHazee4 M3 LRD
    Midwest
    It really annoys me every time I use the frunk....on my brand new car....I have to be super careful about closing something designed to be opened & closed.
