Model 3 maximum battery size is 75kwh
Discussion in 'Model 3' started by dndcruz, Mar 24, 2017.
  1. dndcruz
    dndcruz Member
    Dubai
    Elon replied saying this :
    @kryniog The shorter wheelbase only allows for a 75 kWh pack in Model 3 at current cell/module energy densities.....
    So with this we can assume the largest battery size for the model 3 will be 75 kWh , makes sense why they removed the 60kwh model s , and made the entry version to 75kwh . Now we just need to know the the size of the battery of the base option
  2. vinnie97
    vinnie97 Active Member
    southwest
    Geeze, that's 25 under 100...many were speculating they could do better. Does this mean a max range of 300 miles (~250 in real world conditions most likely)? They'd better increase supercharger buildout in a major way...so far this year it's lapsing big time.
  3. nd4spd569
    nd4spd569 Member
    Dallas, TX
    300 works for me. Makes sense though with his other tweet saying MS would have more range.
  4. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    So, as I posted in the tweet thread, are/do/should we assume the 75 'max' means using 2170 cells since 'everyone knows' that the 3 is being made with 2170s? I.e., that's the 'current' density?
    And thus he's referencing future enhancements for an increase over 75?
  5. juanmedina
    juanmedina Member
    sc
    Interesting. So the top dog will be a P75D. I wander what the 0-60 will be.
  6. widodh
    widodh Model S 85kWh
    Middelburg, The Netherlands
    If weighs less, is more aerodynamic and has less internal losses you use less energy per distance.
    Model S is a heavy and big vehicle. A 75kWh in Model 3 might equal a 90kWh in Model S.
  7. Rashomon
    Rashomon Member
    East Troy, WI
    The small pack will likely be 55 kWh hours then. That should give it just over the Bolt's EPA range, with substantially better highway performance because of the better aerodynamics. The 75kWh big pack will give it over 300 miles of highway range at 75mph, and a likely EPA average overall range somewhere around 300 miles.
  8. Yggdrasill
    Yggdrasill Active Member
    Kongsberg, Norway
    Yes, it's the 21-70s. I expect ~3840 cells in a 96s40p arrangement. EPA range should be somewhere in the 300-330 mile area, depending on *available* capacity.
  9. dndcruz
    dndcruz Member
    Dubai
    I think 0-60 mph in about 3.4 -3.8 seconds would be realistic for the performance version , and beside the smaller battery packs couldn't output more energy , still looks fast though in the video , wonder if it's AWD or RWD
  10. Big-T
    Big-T Member
    Seattle, WA
    How could it be an AWD when Elon just said there won't be AWD on production cars for months 2 minutes before he posted the video of this pre-production car.
  11. Yggdrasill
    Kongsberg, Norway
    #11 Yggdrasill, Mar 24, 2017
    It's likely RWD, being a release candidate. It should still do 0-60 in under 5 seconds, provided it has the largest battery. That's pretty fast. (A bit slower than the original Model S P85, but still fast.)
  12. boaterva
    Right, no AWD for months, and no 'Performance' for 'a year'.
  13. dndcruz
    dndcruz Member
    Dubai
    Well beta prototypes were AWD , and release candidates aren't the productions units to be delivered ? Correct me if I'm wrong please :eek:
  14. boaterva
    You are correct, but they are supposed to be testing the production line and processes. I would think they would be testing what they are going to be producing (first), lol. But who the heck knows, at this point. After today's fire hose, I'm not sure what to think...
  15. ElectroFroggy
    ElectroFroggy Member
    NOVA
    I was hoping for 80-85kw. Looks like the narrower body style of Model 3 equates to 25% less space for batteries.... Bummer.
