Misha is crazy. He said no need helmet since he won't run it fast. Video will be later. Based on stopwatch we made below 8 minutes.
RB 6 pot survived whole track. We had no yellow flags, so it was proper trashing of car. It took 1/3 of XT970 pads - they held well, but they clearly not high temp ones. Unfortunately we did not do any cooling run afterwards and SRF fluid boiled while we were standing for the next lap. I cut 3/4 of heat shields on brake rotors.
We made hot lap with 0 regen -10 stability 70-30 split. Tires warmed up from 28 psi up to 37 psi, so 275 is not large enough for CUP2 on the ring. At last 20% grip was going down.
I have 107mm clearance and we were scrapping bottom and tires were touching arms.
Motors and invertors didn't overheat. Unfortunately I think I don't have logs since I forgot to push start on a track mode
Battery overheated at 80% of the lap. That one lap was 90->50% battery charge. This is not Sebastian video lap where he spent only 20% per lap. Much later than stock.
Turning off regen 100% works.
But to run out whole battery non stop we need to rework active shutter box radiators. Brake pads must be high temp and fluid will be boiled SRF or not - need to make brake scoops or ducts.
MPP/KW springs are too soft for CUP2 tires, should be like 120-140 kg, but it will be harsh for the road.
