I don't think it's possible to break 8 at tourist day. Traffic, speed signs.Seems we have the video now...
3:16 bridge, 11:30 gantry. Still yet to break 8 minutes.
Also want to know which 4 point harness you are using.
Wait a minute... What happened with AP?
Too many horror stories online to go with RB. I’m surprised you Actually went with them. Same issue. Shame that the “kit” they have are attractive.Found out what was banging at the left side after the Ring. It wasnt sway bar which I've changed back to stock. But it was RB floating brake disc which got all bolts loosen. They were all torqued to 9 lbft before and this time they all started to rotate at 4. That fixed an issue, but I think I have more and more reason to abandon those brakes.
They did survive beating with 0 regen, but botls backing off from special patented lock nuts just like that??
That one SAFETY THROUGH TECHNOLOGY » Schroth QuickFit Pro but I have to be honest - I don't know how safe it is considering steep angle of belts behind the seat. I use it only to keep myself planted. And I'm slowly moving towards custom inserts into proper bucket seats with removable rear bar. Just need to find a shop that can make clean installation.Also want to know which 4 point harness you are using.
I'm keep forgetting you snatched 2 cars, lol.Oh the AP Kit is still on the Black car. The MPP kit went on the Red one!
It was that noisy. I already asked others here before if they have same noise from RB rotors. Nothing wrong with them, I believe, except slots are sharp and making that grunt noise. I'm going to post 360 video later so you can compare.@Mash Those brakes seem quite noisy in the 'Ring lap (as in rotor slot 'hum'). Did it sound as noisy as that in the car or is it being picked up more by the camera?
Oh, forgot to ask - how is the stiffness compares vs AP?Oh the AP Kit is still on the Black car. The MPP kit went on the Red one!
How about rigidity?The immediacy of the AP kit is not there. I suspect this has to do with not having AKBS. Of course, the trade-off is no hit in range. I would say it is in-between stock and the AP kit as far as immediacy is concerned.
Otherwise, they feel quite nice, and they look great.
I should have some better insight this weekend.
Grab the @UnpluggedP roll bar and seats. They’re plug and play and the harness bar installs in 15 mins after you do initial assembly. The California guys run it and there’s a video of the install on instagramOk, back to topic. Video gained some traction. Mostly about weird noises I make. I'm preparing a car for October run with Misha again. This time with local shops support.
Minimum: Cooling, Brakes, Seats, Roll bar, 6 point harnesses.
Maximum: Wheels, Tires, more camber, front&rear aero, coilovers.
I'm discussing if a horizontal bar can be added so I can mount seats on the top to it as wellGrab the @UnpluggedP roll bar and seats. They’re plug and play and the harness bar installs in 15 mins after you do initial assembly. The California guys run it and there’s a video of the install on instagram
