I'm not going to address your intense pedantry blow by blow... but on this very first point, which the rest of your lecture is based upon, you're wrong. Physics (which doesn't actually have an opinion) supports what I and others who are more concerned with driving than math, have been saying.
I mean, it factually does not, but let's see why you think so.
The biggest difference between performance and standard brakes isn't really to increase stopping power
That's literally what I've been telling you physics says. So your claim I'm wrong seems....confusing.
, it's to stay cooler for longer, which in turn is to avoid fade. Braking works by transferring energy through friction to heat (the energy has to go somewhere). The larger the surface area, the more heat can be absorbed and dissipated and the longer braking can be effective.
That's also what I've been saying... so again I'm wondering if you're replying to the wrong person or something?
Now if you have a car that can accelerate harder, and you actually apply that ability in general driving, then in many situations you're going to be hitting the brakes more often and harder because you're likely to be going faster at any given point where braking may be needed.
Can you cite some situations where, outside of a race track, you'd be doing this fast, hard, and often enough to cause an issue with the stock brakes?
I ask because even Elon Musk said nobody would notice the P brake upgrade outside of a race track.
What do you know that he doesn't?
Now I agree that this is not necessarily good or safe driving, but that's not the point.
I mean, it kind of is....if you want to drive like a dangerous maniac enough you can likely fade nearly
any passenger car brakes given enough effort.
Cars should be balanced in a way where their brakes match their acceleration. capability. All manufacturers do this.
Except, they don't "all" do that.
The Model S P100D is arguably the quickest accelerating production car in the world.
It has the same brakes as the much slower non-P models.
Oddly, we have yet to see this be a significant safety problem in non-track use.
It's almost like it confirms what I've been saying or something.
And, again, once you switch from acceleration to braking, there's
no difference whatsoever in how quick you got to that speed from which you are stopping.
The brakes on a Porsche 911 GTS are far larger than the brakes on a regular Porsche 911 despite it being lighter and arguably not requiring such powerful brakes according to "physics".
Right. And that difference is
entirely for track use
Funny you mention Porsche- earlier in the thread I quote Car and Driver testing a 911 with 2 different OEM brake systems, that are $10,000 apart (just the brakes).
Guess what they found in non-track panic stop testing?
Both stopped the car in the same distance.
Just as physics requires them to.
Because the brakes don't stop the car- the tires do.
Your hypothetical scenario where both cars are doing 60mph and both need to stop suddenly may be academically correct
Wait... you said I was wrong... now I'm correct? Your post just keeps getting more confusing!
, but it's entirely moot in regards to the reason your more powerful car has more powerful brakes.
I mean, it's really not.
Change 60 to 80 if you want, or even 100... which is significantly faster than any speed limit in the country, and the facts I stated are the same.
A 200 hp car and a 600hp car both doing the same speed and otherwise being equal will both stop from that speed in
exactly the same distance.
"more powerful car" has nothing to do with stopping distance.
If you think it does feel free to explain the physics behind it (hint- you can't)
Incidentally the P100D having the same brakes as the P75 an exception, not a rule. Honestly if you're disagreeing with this, you're a) not really a driver or b) just trolling.
Then it's extra weird you previously claimed "all" car makers do something you apparently already knew wasn't true....
