thebestiam1
Does leaving the car at 100% charged for a day cause any damage to the battery? Specs, 21 SR+ w/ LFP battery. TIA!
Not in my experience (2022 M3 RWD).Does leaving the car at 100% charged for a day cause any damage to the battery? Specs, 21 SR+ w/ LFP battery. TIA!
No.Does leaving the car at 100% charged for a day cause any damage to the battery? Specs, 21 SR+ w/ LFP battery. TIA!
Just did a trip back home. Was around 2c, precon the battery and cabin. Started at 100%. Drove 105km/h 98% of the time. Did 250km. SOC was at 16% when arrived home. I could probably do another 30km.Have a 2023 rwd I took delivery of 2 weeks ago and got a bit of a nasty surprise. I was aware that LFP batteries struggle with range loss in the cold but never expected that to be an issue in Southern Florida. I drove 152 miles across the state with temperatures hovering between 44 and 53 degrees and a speed of 79mph on I75 and you can see the results in the photos. Teslas disclaimers discuss sub freezing temperatures but they need to expand disclaimers if this is a consistent experience. Some range loss was due to the speeds but most seems to be the cold or unaccounted for. Needless to say I needed an extra supercharger stop (152m each way). Also charging seed was limited to 50kwh wich sucked. Anyone else have similar experiences? At what temperatures do you start experiencing range degradation and reduced charging speeds (ex 60,50)?
ABC : Always be charging. Also you have a Long Range with a NCA battery. This is a LFP battery discussion. Different chemistry.With all the discrepancy about charging I called TESLA to find out about how often to charge my 223LR.
He told me to charge it as much and as often as I want and it won't affect the battery. ???????
So leaving at 100% charged and plugged in will not damage the battery, but leaving at 100% and not plugged in causes damage?
No.So leaving at 100% charged and plugged in will not damage the battery, but leaving at 100% and not plugged in causes damage?
The ”damage when left at 100%” is a myth.So leaving at 100% charged and plugged in will not damage the battery, but leaving at 100% and not plugged in causes damage?
They used Panasonic NCA until about Q1 2022.Thank you. Another question, are MIC 2022 M3P batteries NCA?
Not unless the car is exposed to high temperature. Having said that I still make an attempt to minimise the time spent at 100% with my LFP, within reason.Does leaving the car at 100% charged for a day cause any damage to the battery? Specs, 21 SR+ w/ LFP battery. TIA!
Because your battery is aging.Aloha,
Our '22 M3 started out with 272 miles at 100% SOC. then it went to 267 at 100%, now 265. car is 5 months old and temperature isn't an issue here in Hawaii. we were told to charge to 100% at least once a week with the LFP. Any ideas why the range at 100% is dropping?
Mahalo
at 5 months? I have LFP batteries powering my whole house. they don't degrade that fastBecause your battery is aging.
Do your house batteries get frequently discharged and recharged?at 5 months? I have LFP batteries powering my whole house. they don't degrade that fast
I received my car mid May 22. I'm now at 428 Kms at 100%. Which in miles is 266Aloha,
Mahalo
every day for the last 8 years , but I do my best to keep. them above 50% SOC. they're the sole source of power for our homeDo your house batteries get frequently discharged and recharged?
Can I ask a Noob question on supercharging an M3 LFP? Do you in fact attempt to charge to 100% on the level 3 superchargers? Or is it a waste of time (as it slows down when it gets to 80%?). I see that the 80-100% charging takes roughly 40 minutes vs. 20-80% that takes 20 minutes?I did a road trip from the west coast to Newfoundland and back with a new model 3 lfp. Lots of supercharging along the way. The car now has 20000km and gets the same 430km on a full charge. During the trip it very quickly dropped to 434km full charge and then reduced much more slowly.
The fastest way to travel is to Supercharge enough to get to your next destination once the rate starts slowing down significantly. That's usually between 60-80% depending on the speed and distance to the next Supercharger.Can I ask a Noob question on supercharging an M3 LFP? Do you in fact attempt to charge to 100% on the level 3 superchargers? Or is it a waste of time (as it slows down when it gets to 80%?). I see that the 80-100% charging takes roughly 40 minutes vs. 20-80% that takes 20 minutes?
I’d almost stop more often instead just to charge to 80% but I don’t know if that’s not great for an LFP battery.
