The [Square root of time] calendar aging behaviour is most certainly valid for these LFP’s as well, as it is for all lithium batteries.
The reason for the calendar aging is the build up of SEI, which in turn protects the battery by reducing the rate of the calendar aging.
We do not need to be worried about that the calendar aging continue at a high rate.
It will follow the square root of time. It might bee that the BMS has hard measuring the real capacity so in a short time interval it might look different.
Cyclic aging is very small for these cells do we can disregard it.
So the degradation will flatten.
Teslafi show two different starting ranges.
The calculated average combines these, so it doenst work. But drawing a approximate line for each starting range show a clear square root form, specially for the higher range version.
