I'm not sure if they still include it. You should check with your rep. It was an a-type in mine and in the glove box. It's there to keep it secure. While c-type is faster, I'm not sure it would make that much difference. Recommend you check first.I pick up my 2023 Model 3 next week and want an SSD for Sentry. Does it use USB A or C and which SSD is the best recommendation?
So excited!
It looks like you have a USB drive and the SSD both plugged in? Also which housing unit is holding the SSD in that pic? Was it plug and play?I picked up my Model 3 2 weeks ago. Its USB A in the glove box. It comes with a 128gb USB drive but I found some of the saved videos looked like they were randomly dropping frames. I swapped it out with a 1tb Samsung T7 SSD drive and the videos are now smooth. Looks like Tesla is going to sell their own version but is $350 for 1tb. The T7 drive was $90.
Yup. SSD drive contains Sentry and dash camera videos. USB drive(the one that came with the car) is for Boombox horn shenanigans. The housing for the SSD drive is a 3d printed part I designed. Its just a place holder and I may redesign it later on. SSD drive is plug and play. Just plug it in and format it in the car. Whatever you buy, it only needs to be USB 2.0 and A sustained write speed of at least 4 MB/s. The drive I got far exceeds the minimum requirements but is cheaper than what Tesla will offer even including the cost of the USB hub and shorter USB cable.It looks like you have a USB drive and the SSD both plugged in? Also which housing unit is holding the SSD in that pic? Was it plug and play?
Do you have an STL file for that? Thinking about getting the SSD, and that looks nice . . .Yup. SSD drive contains Sentry and dash camera videos. USB drive(the one that came with the car) is for Boombox horn shenanigans. The housing for the SSD drive is a 3d printed part I designed. Its just a place holder and I may redesign it later on. SSD drive is plug and play. Just plug it in and format it in the car. Whatever you buy, it only needs to be USB 2.0 and A sustained write speed of at least 4 MB/s. The drive I got far exceeds the minimum requirements but is cheaper than what Tesla will offer even including the cost of the USB hub and shorter USB cable.
I do but thats a palace holder that I made. Here is the current version im working on. When Im happy with it, ill put it on Thingiverse. Due to copyright, I may have to remove the tesla logo and lettering.Do you have an STL file for that? Thinking about getting the SSD, and that looks nice . . .
niceI do but thats a palace holder that I made. Here is the current version im working on. When Im happy with it, ill put it on Thingiverse. Due to copyright, I may have to remove the tesla logo and lettering.
Its a hub I got off amazon(link below, if allowed). There are a bunch of different ones that I found but this one looks like its a factory part.My glovebox only has a single USB port. Are multiple ports now standard on newer models or is that a custom hub in your photos?
That looks like a nice inexpensive way around the no-data-connection issue with the USB-C ports in the console. Cheaper than buying the data module and necessary cabling.Its a hub I got off amazon(link below, if allowed). There are a bunch of different ones that I found but this one looks like its a factory part.
YONZEE Glove Box USB Hub for Tesla Model 3
The glovebox port is USB 3. It should have no problem supporting simultaneous video, music, and game controller usage. I went with separate video and music memory because the USB drive alone had glitches when I tried to use it for both video and music. Putting the video on the SD card resolved that issue. A really fast USB drive would fix it too, but costs more and uses more glovebox space.That looks like a nice inexpensive way around the no-data-connection issue with the USB-C ports in the console. Cheaper than buying the data module and necessary cabling.
But isn't the glovebox USB-A port USB2 speeds only? I don't get why the USB3 blue port on the hub?
Did you get something to put out on Thingiverse?I do but thats a palace holder that I made. Here is the current version im working on. When Im happy with it, ill put it on Thingiverse. Due to copyright, I may have to remove the tesla logo and lettering.
I did, Link below,Did you get something to put out on Thingiverse?
Have you had any issues using the Hub with the SSD for Sentry/Music? Just seen some spotty reports when people use a hub for these purposes.Its a hub I got off amazon(link below, if allowed). There are a bunch of different ones that I found but this one looks like its a factory part.
Only minor one. Sometimes when trying to view saved videos it takes extra time loading. If I exit out and go back in it loads fine. Playback of videos on the car works fine. I don't use music on the other USB drive so I don't know how it works with music.Have you had any issues using the Hub with the SSD for Sentry/Music? Just seen some spotty reports when people use a hub for these purposes.
