Have you considered the MPP rear subframe inserts as well?Anybody running either of the below? Seem like a worthwhile upgrade to stiffen things up in the rear. I would like to get rid of the jittery/unsettled feeling that i have in the rear of the car.
Big agreement there. I've said since almost day 1 with this car that rear compression travel feels very limited. That said, I'm assuming this is about mid-corner feel, not bottoming out over big dips or bumps.I believe that unsettled feeling comes from hitting the bump stops. Even at stock height there's only ~3/4" of rear suspension travel before the bump stops come into play. Shortening them makes a very noticeable difference in handling feel but also makes high-center scraping on driveways even more common.
I would not touch the front subframe at it is designed to fold upon itself in a heavy front end crash. The subframe will basically fold over. I have seen crash test video footage doing just that. The ultra racing front subframe bar seems like it would restrict that movement.Anybody running either of the below? Seem like a worthwhile upgrade to stiffen things up in the rear. I would like to get rid of the jittery/unsettled feeling that i have in the rear of the car.
I have not upgraded to their arms just yet however i have really been thinking about it. I suppose from the responses here their sub-frame bushings will be a worthwhile upgrade!Big agreement there. I've said since almost day 1 with this car that rear compression travel feels very limited. That said, I'm assuming this is about mid-corner feel, not bottoming out over big dips or bumps.
As for stiffening the rear, @canasion35 have you upgraded all your rear control arms yet? (whole arm replacements or otherwise) MPP's writing on this says that should be a first step, not much point in stiffening the rear subframe if you still have stock control arm bushings. I can't vouch for that from my own experience, but I'm certainly inclined to trust MPP on it.
This is interesting. I just picked up a Hardrace brace that couples the compression arms and nothing else — it looks like they specifically engineered it not to interfere with this front-to-back subframe compression.I would not touch the front subframe at it is designed to fold upon itself in a heavy front end crash. The subframe will basically fold over. I have seen crash test video footage doing just that. The ultra racing front subframe bar seems like it would restrict that movement.
watch around the 1:25 mark and you can see how the subframe compresses upon itself. - I would not touch that area.
Have you installed the brace and do you like it.This is interesting. I just picked up a Hardrace brace that couples the compression arms and nothing else — it looks like they specifically engineered it not to interfere with this front-to-back subframe compression.
The music in that video is way too happy for the setting![]()
Not yet, it looks solid but I’m waiting on a couple of other minor parts before I get under the car again for real. Will report backHave you installed the brace and do you like it.
Oh yeah that one would be fine. I was looking at the first photo OP posted that ties those into the FLCA mounting points!The brace just reinforces the compression arms, it doesn’t really cross paths with the FLCA.
See photos 7-9 in Hardrace Front Lower Brace for Tesla Model 3
