ModelNforNerd
again, not really, you continue to miss the point.
i understand that you use your car for long-travel all the time, but you need to understand that it's not the common scenario.
said that, i also said that it will probably be unwise to use the ice car since the comparison was made on a prius ( wich is not exactly an ice car ) but you really this it is, you can go and use your ice car, if you really think it will be cheaper
but again ( and this is the 3° times ) you don't need to be cheaper EVERY DAMN TIME, you need to be cheaper on average!
with the time even the supercharger would be a lot cheaper since we hope that the eletrcity bill will be lower due to more renowable energy like off-shore turbine, battery to fix the problem of high peak moments, solar panel everywhere etc, but even in the case that FOR NOW it would cost the same as a prius DURING THE LONG TRAVEL it will be ok.
Due to the language barrier, I'm going to respectfully bow out of the conversation at this point, as I don't want to insult anyone, or expend any more energy than I have to trying to get my point across.
In the end, what works for me, in the US, will be different than what will work for you in Italy.
Good luck.
