45 psi was too harsh a ride for me so I dropped it to 40 psi and have kept it there for 4 months. I still get excellent range (the entire 310) and have averaged 249 Wh/m over 5,200 miles. I feel vindicated now that Musk says 39 psi is okayMy only issue is that on cold mornings I get the low pressure warning on the screen that takes about 15 minutes to go away. I wish the tire pressure warning was synced with the external temperature sensor so that it did not give false warnings when cold.
Warning: Under-inflation is the most common cause of tire failures and can cause a tire to overheat, resulting in severe tire cracking, tread separation, or blowout, which causes unexpected loss of vehicle control and increased risk of injury. Under-inflation also reduces the vehicle's range and tire tread life.
Warning: Check tire pressures using an accurate pressure gauge when tires are cold. It takes only about one mile (1.6 km) of driving to warm up the tires sufficiently to affect tire pressures. Parking the vehicle in direct sunlight or in hot weather can also affect tire pressures. If you must check warm tires, expect increased pressures. Do not let air out of warm tires in an attempt to match recommended cold tire pressures. A hot tire at or below the recommended cold tire inflation pressure is dangerously under-inflated.
18" Michelin Primacy MXM4 = 45 psi recommended (same as Model S). This gives max range, and you still get a good ride because the Primacy is a grand touring tire.
19" Continental ProContact RX = 42 psi recommended (similar to 21" Model S). This gives a less harsh ride than 45 psi, important because the 19" tires have less sidewall and less cushioning.
I believe these will be the pressures posted on the door jam of each Model 3, and it will reflect the tires/wheels that the car was ordered with.
Elon says "Best way to improve ride is drop tire pressure to ~39 psi. 45 psi is best range, but lower comfort."
Elon Musk on Twitter
You do know the 39 psi he is talking about is in the mornings when the car is cold on those coldest mornings? So is the 42 and 45 we are talking about. If you set it to 40 in the afternoon on a warm day it is too low compared to his recommendation of 39 cold and that is why the car is warning you every morning.
40 hot might be 35 cold for all we know. You have to test cold to be sure. If you say it is warning you at 39 cold you'll have to be more specific so we are sure you know the difference.
Here are the warnings about this in the Model 3 owners manual
Excellent point! My son and I argued this for over an hour last week. Tire pressure drops ~1 psi per 10º F, so if you fill your tires at 40 psi at 70' F, it will read 39 psi at 60º, which will trigger the low tire pressure warning (Tesla psi warning is set at 39 psi). We researched this ad issue nauseam and could fine no standard temperature for "cold tire pressure". Does cold mean 50º, 60º 70º?? The standard temperature for "cold" tire pressure makes a huge difference because it could vary by 3-5 psi depending on what it is. That being said, the tire pressure warning should not trigger if the tires had the correct psi at the standard cold tire temp. (whatever that is), because it's giving a warning for a temperature that is lower than the official cold tire standard. The warning should be coordinated with the temperature sensor and only give a warning if the psi is too low for the corresponding change in psi as it relates to variation from standard "cold" tire temperature.
P.S: If you know what the standard temperature is for "cold tire pressure" please share!
Cold Tire Pressure - The air pressure in a tire that has been standing in excess of three hours, or driven for less than one mile.
There is no standard temperature for "cold" tire pressure. The meaning of the phrase is that the pressure should be set when the tires are at ambient temperature, before they have been driven on. After driving a few miles, the tire temperature has increased above ambient, and the pressure reading will have correspondingly increased.
Yes, you are correct that the cold tire pressure will indeed vary with temperature, and this will require that you adjust pressure seasonally so that the cold tire pressure is correct. You will need to bleed off air as the average daily temperature gets hotter in the spring and summer, and will need to add air as the average daily temperature gets cooler in the fall and winter.
The reason for this is that tire pressures are "gauge" pressure, meaning that the pressure reading is the difference between the internal tire pressure and the atmospheric pressure outside the tire. Both the internal tire air and the external air are affected by temperature, but there is a fixed mass of air inside the tire which also has a fixed volume. By the ideal gas law equation, PV=nRT, an increase in T will cause an increase in P, while V/n/R are constant. Outside the tire, the volume is not constant (air can use more space around the Earth), so increase in T does not cause an increase in P. Since absolute pressure inside the tire goes up but outside the tire doesn't, then the gauge pressure goes up. The pressure change due to temperature is approximately 1 psi for every 10 degrees F.
The bottom line is that if you want to set your cold tire pressure to 42 psi, you need to do this after the car has been sitting for several hours and the tires are at ambient temperature. The absolute temperature of the air doesn't matter. If the absolute temperature of the air changes radically (say a cold front comes through and average temperature drops from 80F to 50F), then you need to readjust pressure to 42 psi again, also after the car has been sitting for several hours.
For similar reasons, you may also need to adjust tire pressure if you make a large altitude change on a road trip. Increasing altitude increases gauge pressure, requiring you to bleed air at high altitudes to restore the correct pressure. Pressure changes about 1 psi for every 2000 feet altitude.
Sometimes you'll see temperature and altitude pressure changes offset each other. For example, drive from the Las Vegas strip (elevation around 2000 feet) to the Mt. Charleston peak to the west (elevation 11,400 feet). This would increase pressure about 3 psi. But the temperature might also drop from 80F at the strip to 50F at the mountain peak, reducing pressure 3 psi. Tire guage pressure would stay approximately constant.
This is very interesting, thanks for your detailed description. I'm still perplexed by the inaccuracy of the whole system though. For example it is not unusual to have temperatures above 105º F where I live and lows in the 60's. So with a 40-50º swing, my tire pressure will vary by 4-5 psi. It would not be realistic to change my tire pressure twice a day to account for ambient temperature swings. If tire pressure is so important (according to pretty much everyone), why do we have such an inaccurate way of calculating it? Frankly, I'm starting to think the psi is more about an average than a set number.... especially if my tire pressure can change 5 psi in one day just sitting in my driveway and change by as much as 10 psi when hot from driving. If it was really important to have an exact tire pressure cars would have systems that automatically adjust psi to maintain a constant number regardless of temperature. Which gets back to my point, the tire pressure warning on the Model 3 is pointless if it is not calibrated with ambient temperature. For example, if it's 20º F in the morning and my tire pressure has dropped to 40 to 36 psi, I'm not going to get out my compressor and top them off to 40 psi.... so why bother giving me the warning?
For any tire, there are a range of pressures that are safe. Lower bound on the pressure range is generally defined by the maximum weight of the car + cargo, the car's top speed, and the load rating of the tire. Higher bound on the pressure range is usually the manufacturer's maximum cold tire pressure stamped on the sidewall. Any pressure within this range is safe for driving, but is not necessarily optimum for any particular task:
Max efficiency = higher pressures
Soft ride = lower pressures
Max traction = lower pressures
Best handling = somewhere in the middle
Usually, the car manufacturer tests various tire pressures within the safe range, and determines a pressure that balances the various needs of the car as best as possible.
It's not inaccurate, it just reflects reality.
The gauge pressure accurately and directly correlates with the internal force on the tire and the resulting stresses in the tire's rubber, steel, and nylon belts. The objective of the pressure selection is to have a constant amount of force on those items, as the tire can perform its desired functions with that amount of force on it.
Changing atmospheric pressure changes the gauge pressure and therefore the internal force on the tire materials.
As dhanson stated above, you should have enough pressure in the tire to clear the warnings (and preferably bring the tire to the recommended pressure) when the tire is cold (has not been driven in several hours). Additional pressure that shows up on the gauge after the tires are warm from driving does NOT need to be bled off -- this extra pressure due to driving temperature increases is already accounted for by the manufacturer, even if that pressure exceeds the maximum sidewall pressure value.
In short, do not worry about temperature swings during the day or temperature increases due to driving. Adjust your cold tire pressure once a month to the recommended pressure value on the door placard, and you will be fine.
with a low of 50º and a high of 90º, it would make the most sense to adjust tire pressure to the lowest temperature of the day (50º). Does that seem correct?
