TeeThreee
The steering shroud is surprisingly easy to remove and replace.
There are several aftermarket steering-mounted displays, and their installation video shows how to get the upper shroud off (no tools required other than a plastic pry tool if you want: I did it without)
Once the upper shroud is off, a single torx screw (centreline of bottom shroud) allows the lower shroud half to drop away.
Here is the process to remove the upper shroud. Once you have got to the point where the shroud is off there is no need to watch further.
Here is the instruction video:
