iKhalid
Anyone knows when the weight became lighter? My model S left the factory in Feb 2014... Did I get the lighter version? (I doubt it)
There was a dyno test of a P85 done in Canada which had the P85 come in at 336 HP at the wheel.
But know that there is a difference between peaking over 320kW from the inverter and what power you actually get to the wheels.
1) Could you mean 436 HP or even 336 kW? In another test last year they got 428 HP.
2) In an ICE vehicles specs, is the listed horsepower at the wheels?
Thanks for the clarification. Now I feel betterOk, so for those who hadn't heard or keeping tabs on this one, the weight has been modified slowly over time. As they have improved different parts, the weight has just naturally dropped. There is no definitive way to say what you have and don't have. The comment from the Earnings Call (feel free to go listen to it or read a transcript!) was that the car the released in 2012 and the car today are two different cars in terms of weight. They have shed "a couple hundred" pounds... but it wasn't noticeable changes from week to week, but rather small adjustments over time. Hope that helps
And there you have it folks...
Even Tesla enthusiasts complain when Tesla beats expectations.
Maybe this is a surprise to most of you, but kW measures the exact same thing as horsepower. 320kW = 429HP, at the inverter. Dyno is just effectively measuring efficiency, when it's not overloaded.
Yes. I've only seen over 320 in my S85 once or twice. ~90% SOC, beginning of trip (a couple of 100 m from home) and ~25 deg C outside. I'd say it looks exactly like the screenshots above. But on an S85 and not P85.If you look at the DragTimes video, you will see that his SoC is fairly low, around 40 %. Even so it almost reaches 320 kW. It actually limits power and does 0-60 in 4.9 anyway.
When I get the dashed "power limited" line I can feel that it's slower (ehrm - less quick) than usual, and I think I can feel it before the dashed line actually appears. I think it has to have a high state of charge and the battery must not be cold to go over 320.
Ehm. No. If the scale is logarithmic, then the middle mark between 640 and 320 wouldn't be 480. It would be lower. Or do you assume that the scale is linear between each printed number?Using some rough guesses, The top of the gauge would be 640. Based on the two visible tick marks and the spacing of the line on the current read out, I can make a guess that it is pretty close to the equivalent of one tick mark up from the 320 point with there being 6 ticks to get to the top. The middle point would be 480 so one tick would be ~53.3 kW.
Try that with 90% but from 30-90 km/h and I think you will see it edge past 320.Oops. I said I agreed, but you're right, of course.
I did some testing today. I charged from 80 % to 90 % on a supercharger while buying lunch, disconnected and parked away from the chargers as it was finished when I got back. Then I ate for about 20 minutes and left. Ambient temp about 20 deg C. Accelerating from 100 to 125 km/h it would repeatedly hit 320 and stay there, but the needle did not completely clear the 320 mark. It edged above the mid-point of the mark every time, though. Later, at about 75 % SoC, it stopped a pixel or two below 320.
I swear I've seen it pass the 320 mark by several pixels on earlier occasions, but I could not make it do it today.
I'm convinced SoC affects how much power you get.
- - - Updated - - -
You are right, hrmmm if only there way a way to sort out the scale... I am not aware enough about log math to get the right number... Hrmmmm.
Will it record it when it when it's only a few seconds long event?Guys, just read the actual value from the API and there is no sorting out that needs to be done. Grab yourself a copy of VT or write your own.
While driving, the streaming API provides data 4 times / second.Will it record it when it when it's only a few seconds long event?
