@Olen - May I ask you how you are retrieving the ID in PHP for subsequent REST calls? With the previous API I had no issues, but last night I made the move to owner-API. Now, PHP is returning my ID in scientific notation, which is incompatible with the Tesla servers. But, not to worry, I'll just use a sprintf function which displays the number correctly; however it is xxx864 whereas if I run a curl command from terminal on my desktop if comes out to xxx571. I'm truly baffled as to how the first 16 digits are exactly the same and yet my last 3 digits are not.
Vehicle_id is used in the streaming API. Not sure why they have two different IDs.
[FONT=Menlo]{"response":{"reason":"already_set","result":false}}[/FONT]
Can someone post the command syntax for "set charge limit"? I'm getting a 404 when I hit that API. Checked the docs but they don't appear to have been updated for owner-API.
curl -H "Authorization: Bearer e7434f7a1...96b739" \
-H "Content-Type: application/json" \
--data '{"percent" : "90"}' \
-i [URL="https://owner-api.teslamotors.com/api/1/vehicles/5854725160300941028/command/set_charge_limit"]https://owner-api.teslamotors.com/api/1/vehicles/58547...028/command/set_charge_limit[/URL]
System.Net.WebException: The remote server returned an error: (429).
My logger hasn't changed since August of 2013 but has been reporting
for the last day or so. I haven't used any other REST to talk to the car in at least a week, so no increase in querying rate on my end. They may be having "the Azure bug" again.Code:System.Net.WebException: The remote server returned an error: (429).
By "the Azure bug", I'm referring to my working theory that all Azure VMs on the same host or cluster or whatever probably come through a common hub/router/whatever and Tesla's throttling probably doesn't filter it's load throttling by account/car id.
Rounding issue?
