I don't think you can determine this remotely but depending on what you are looking at trying to do you might be able to accomplish it in a different manner. For example, it shouldn't be too hard to determine if you car is on the same LAN as the computer that you are running your code on using something like arp or nmap and looking for the MAC Address of your car. So in that way you could at least determine if your car was on your home Wifi or not. And for me (and probably lots of folks) not being on home Wifi means that I am on LTE.Is there a way to remotely determine whether the car is currently using WiFi rather than LTE? I don't think it's in the API as documented but I thought this thread might be a good place to ask.
jstenback/pytesla · GitHub is an updated version of pytesla that I spent some time hacking on, and adding some stuff to (streaming of events from the car primarily). Works fairly well.
@tliving - can we actually use some of these to change states?
And the homelink_nearby field could presumably be used for geofencing applications for non-Tesla applications if you desire - like turn on your lights and TV when your Tesla gets home.
%@/api/1/vehicles/%@/command/charge_start
%@/api/1/vehicles/%@/command/charge_stop
%@/api/1/vehicles/%@/command/charge_port_door_open
%@/api/1/vehicles/%@/command/charge_port_door_close
%@/api/1/vehicles/%@/command/auto_conditioning_start
%@/api/1/vehicles/%@/command/auto_conditioning_stop
%@/api/1/vehicles/%@/command/door_lock
%@/api/1/vehicles/%@/command/door_unlock
%@/api/1/vehicles/%@/command/trunk_open
%@/api/1/vehicles%@/command/sun_roof_control
%@/api/1/vehicles/%@/command/sun_roof_control
%@/api/1/vehicles/%@/wake_up
%@/api/1/vehicles/%@/command/honk_horn
%@/api/1/vehicles/%@/command/flash_lights
%@/api/1/vehicles/%@/command/charge_standard
%@/api/1/vehicles/%@/command/charge_max_range
%@/api/1/vehicles/%@/command/front_defrost_on
%@/api/1/vehicles/%@/command/front_defrost_off
%@/api/1/vehicles/%@/command/rear_defrost_on
%@/api/1/vehicles/%@/command/rear_defrost_off
%@/api/1/vehicles/%@/subscription_preferences
%@/api/1/vehicles/%@/command/remote_start_drive
%@/api/1/vehicles/%@/command/reset_valet_pin
%@/api/1/vehicles/%@/command/set_valet_mode
%@/api/1/vehicles/%@/command/autopark_request
%@/api/1/vehicles/%@/command/trigger_homelink
%@/api/1/vehicles/%@/data_request/drive_state
%@/api/1/vehicles/%@/data_request/charge_state
%@/api/1/vehicles/%@/mobile_enabled
%@/api/1/vehicles/%@/data_request/gui_settings
%@/stream/%@/?values=speed,odometer,soc,elevation,est_heading,est_lat,est_lng,power,shift_state,est_corrected_lat,est_corrected_lng
%@/api/1/vehicles/%@/data_request/climate_state
%@/api/1/vehicles/%@/data_request/vehicle_state
%@/api/1/vehicles/%@unavailabledisabledstandby
%@/api/1/logs
%@/api/1/notification_preferences
%@/api/1/vehicle_subscriptionsios-productionwakingonlinestatecloseventopen
%@/api/1/vehicles/%@/command/set_tempsdriver_temppassenger_templat%flonstart_forwardstart_reverseabortaction
%@/api/1/vehicles/%@/command/set_charge_limitpercent
There are better ways to do that if you have the correct hardware. Chamberlain has something called MyQ that has an API that you can use for garage doors. And it will know the correct state of your doors which your car will never know. And you can often retrofit older hardware with a hub.Perhaps someday the API will be able to open the garage doors.
The newest version of the mobile app claims you can open/close your garage doors in addition to summon but I can't find any way to do that from the new app and nothing in the API supporting it:
Decrypted the iOS app and found these commands:
Some commands seem new:
autopark_request
trigger_homelink
No we don't since someone can always manually operate the door without the car knowing and therefore the car does not know the state. Maybe I am wrong but I am guessing that the car can only send a toggle door command via Homelink and not a discrete "Door Open" or "Door Close" command. And, unless it can have a two way interface with your door opener or a tilt switch, it doesn't know the state of your door with certaintly.We have all the hardware we need already. No need to add additional equipment.
The Tesla Homelink is kind of like a Harmony remote control. It thinks it knows the state of your devices but it can get out of sync due to signal issues or manual intervention
I am more concerned about it sending the close door when I leave without me having to worry whether it worked. Many of us seem to be having issues with AutoClose.Seriously, i want to use this to get into the garage. I'm standing on the other side of the door. I don't need the car to know if the door is open or closed. I just want it to send the signal.
I tried using the homelink button in my app after plugging the charging cable in and got a failure. Try using the homelink api call with the fob in proximity to the car, and charging cable unplugged.
Do you have a homelink button in the Tesla app? I can't find one. If you do screen shot please
So it is on the Summon screen - that's bad planning as that screen doesn't exist for anyone outside of the US, or at least it doesn't exist for me in Canada (and I have updated the app).It's the button on the top right.
