Moved from
Feature Request Compilation From /r/teslamotors
· Red light / stop sign warning if approaching without slowing and yellow light assist to recommend when to stop or go through based on traffic/time/current speed. With this, make the time before going into "hold" mode (on cruise control) much longer if no stops or red lights are detected.
· A not so drunk navigation system
Also, a green light detector, that shows an alert on the display somewhere (for all three light colors if possible), and chirps at you if you don't respond in 3 or 4 seconds. Traffic lights are sometimes close to in line with the sun and it's difficult to see them in the glare. A different viewing position (one that I can't get my eyeball to) might help.
Speed limit alert threshold adjustable, without changing the speed limit lines on the white/blue tape on the speedo. presently, if I'm going 1mph over, it displays the warning over the "fuel gauge" almost constantly. if I change the threshold, it changes the blue/white tape threshold, too.
Teach the nav system to stay off residential streets when just passing through an area.
An option to force re-sync for addresses and numbers in my phone. A friend moved and changed his address on my phone. Now I have to tell the car /and/ phone to forget each other and then re-pair them. petty, but trivial to fix. do NOT do it automatically; there may be a reason I'm not syncing.
nav should be more sophisticated about generic things. For example, if I ask for a rest area while on the freeway, the ones behind me are not particularly useful, and when I'm in unfamiliar territory, "helping" me by giving me its name is not helpful at all. I'm asking how far it is to the next one. same is true for generic commercial things, like starbucks and costco. There are cases where the one behind may be useful. if it gives both a distance and
direction, I have a chance of figuring it out.
similarly, the parser is needlessly obtuse. if I say "Navigate Centralia Supercharger" from the Seattle area, it's much more likely that I mean the supercharger in Washington state, rather than the town in Pennsylvania that has no supercharger.
More trip odometers. I can't think of a reason there shouldn't be hundreds of them. similarly with charging. there should be an easy way to get a complete log of every time I charged the car: volts, amps, start and stop time, SOC before and after.
An actual compass display. I can deduce what my heading is from the arrow on the map but I want a real compass.
seconded on the interior temperature.
I want a low-volume horn. just yesterday a couple was crossing the street in the middle of the block on a one way street, starting while the light was red, protecting them. but something on one of the buildings caught their attention and they stopped in the middle of the street, and they didn't notice the light change or my nearly silent car approaching, and just stood there, looking up and away from me. I tooted the horn, which startled them. put a small speaker under the nosecone that plays some noise when I push a button on the top line of the big display. let me pick it, like the ring tone on my phone. mine would be the bell from a kid's bicycle.
seconded on the "nerd" options. temperature of the battery and motor(s), whether the fan is running.
add projected range, miles driven and total energy used since last charge onto the energy display,
especially the little one behind the steering wheel.
I want a way of making the names of streets on the moving map get temporarily bigger, so I don't have to put on my reading glasses.
--Snortybartfast
