SabrToothSqrl
I forgot the rebate: $833 / 27,000 = $0.03085 / mile. Still more $ than the RS, but with fewer tire changes and more grip = better cost and value long term.
Amazing - you're a little brave to own one that far from a service centre!Winnipeg, Canada area.
A lot of folks have, including me. There's nothing magic about Tesla alignment. The trick is to find a decent alignment shop.Has anyone had an alignment done outside a Tesla shop?
jerry33,A lot of folks have, including me. There's nothing magic about Tesla alignment. The trick is to find a decent alignment shop.
HelloYea, I read that about the UTQG, making it near worthless. But the Pirelli's have a 70k warranty... and arrive to my house today, so I guess we shall see! 40k does sound nice, but is that 40k with what style of driving? I tend to punch it... pretty much all the time... lol
I thought 45psi was recommended....48 seems high especially when you drive and the tire temp increased by 2-5 degrees depending on temp and pavementI replaced the OE Goodyears at 28,000 miles. Now the Michelin Primacy tires are down to 5/32 after only 20k miles. I'm really surprised by that because we keep the tires inflated to around 48 PSI and don't drive aggressively. I'm very disappointed in the life of the Michelin Primacy tires. I've had them before and have never had them wear out this quickly.
Wouldn't a slightly higher PSI reduce tire wear?I thought 45psi was recommended....48 seems high especially when you drive and the tire temp increased by 2-5 degrees depending on temp and pavement
as ZeeDoktor has said, if tires are over inflated, they will wear from center....you will also have a harder ride because they are expanded....Softer ride with under inflated tires will wear on the outsides........if you are only wearing down on the inside or the outside, have the alignment checked....Wouldn't a slightly higher PSI reduce tire wear?
