Above = a good sum up how I feel it at the moment still with the yoke.No issues, been doing it for thousands of miles in my 3. I have a round wheel in my S as well, again no issues. It is bigger than my 3's wheel so actually a bit more comfy. I like that I can grab it lower. I have a lot more options to hold it.
With the yoke there was pretty much one place that worked for me when on a trip and TBH it was pretty comfy until I got tired of that position. You may find other "holds" that work for you.
I'd love to see a photo. The only thing I have even partial blockage is the little speed limit sign. If so much is being blocked, you are clearly the worst case I've heard of so far.I had this round steering wheel for about a week now, and it's blocking my front dash. I can't even see the speedometer, etc. if I adjust the steering too high, it's no longer comfortable! I thought about going back to the yoke!
Here it is.I'd love to see a photo. The only thing I have even partial blockage is the little speed limit sign. If so much is being blocked, you are clearly the worst case I've heard of so far.
I would say you move the steering wheel to a comfortable position. If you’re lucky it do not cover the instruments.Why don't you move it up?
I tried that but then it’s not comfortable.Why don't you move it up?
Instead of the yoke Tesla really should have done a heads up display. Useful without taking steps back.I just updated from a yoke to the round wheel on my 2022 X. I'm really surprised with how much of the display it blocks. I can't see the speed limit anymore nor some of the other icons. I'd expect them to have that figured out either by making the top of the wheel a bit taller or changing the display to lower the icons they know are going to be cut off.
Definitely easier to park and drive in tight spaces with the wheel over the yoke!
It wobbles a bitOEM round wheel looks nice. For those that have it, when rotating the wheel does it "wobble"? Like the axis of rotation is not in the center of the wheel? Also does anyone know how it compares to the older pre-refresh model S/X wheel? I had a 2016 X previously and I thought its steering wheel could have been a little smaller (overall diameter). Thanks.
Not sure I would call it wobbling. I think the flat bottom gives you that sensation when turning the wheel but I'm not actually sure it wobbles per se.OEM round wheel looks nice. For those that have it, when rotating the wheel does it "wobble"? Like the axis of rotation is not in the center of the wheel? Also does anyone know how it compares to the older pre-refresh model S/X wheel? I had a 2016 X previously and I thought its steering wheel could have been a little smaller (overall diameter). Thanks.
That is the same I'd say about the Hansshow wheel. I find it does obscure the dash less as well than my Tesla wheel did.Not sure I would call it wobbling. I think the flat bottom gives you that sensation when turning the wheel but I'm not actually sure it wobbles per se.
Not being able to see the speedometer sounds extreme. Try moving the wheel higher and then moving your seat to make it comfortable - perhaps sit a bit more upright?I had this round steering wheel for about a week now, and it's blocking my front dash. I can't even see the speedometer, etc. if I adjust the steering too high, it's no longer comfortable! I thought about going back to the yoke!
The wheel is not perfectly round so it will "wobble" a bit. But pretty much every sporty-type vehicle has a wheel like that these days - from MB to BMW to Corvettes, etc.OEM round wheel looks nice. For those that have it, when rotating the wheel does it "wobble"? Like the axis of rotation is not in the center of the wheel? Also does anyone know how it compares to the older pre-refresh model S/X wheel? I had a 2016 X previously and I thought its steering wheel could have been a little smaller (overall diameter). Thanks.
