JuanWick
New Member
The macboost instructions are not clear at all.The Macsboost kit saves time, aggravation, money and gets you back on the road quickly with a properly engineered solution and with product support should you need any.
I finally figured out the adjustment for 57mm length and installed , but I don’t understand the recommendation for adjusting the toe-in.
The recommended adjustment is 1/2 turn, but that amount of adjustment on the offset bolt will move the toe arm out and back in.
What is the correct toe-in spec, so I can have it adjusted by alignment shop?
